Rainbow Density Lab
Introduction: Rainbow Density Lab
About: I'm a middle school science teacher going on 17 years in the classroom. I've taught 6th, 7th, and 8th graders. I'm constantly looking to improve my instruction and Instructables is one of the places I sear...
This rainbow lab is a "layered solution" using different densities of salt water. The materials are super cheap and the end result is impressive.
Students are engaged in a hands-on experience that encourages real-world connections and forces them to follow the directions. The experiment also allows the flexibility for students to create their own experiments at the conclusion of the lab. The lab usually takes between 45 minutes - 1 hour to complete (excluding extension questions).
A few of the concepts that can be tied to the lab include; the difference between a solvent and a solute, what it means for a solution to be saturated, density, how liquids with different densities interact, investigate other ways to stack solutions, and students will be able to identify where liquids of different densities might come into contact in nature.
LAB SHEET
Step 1: Materials
Food Coloring
Water
Salt
5 small beakers
100 mL graduated cylinder
Spoon or stirring rod
Scale or electronic balance
Pipette
Masking tape
Pen / Marker
Step 2: Procedure
1. Label each of the 5 beakers 1-5.
2. Into each beaker, add salt and water in the amounts identified on the attached worksheet.
3. Stir each solution well to dissolve ALL salt.
4. Add two drops of food coloring in the amounts identified in the table on the worksheet.
5. Gently pour about 20 mL of the solution from beaker 1 into the graduated cylinder. Helpful hint: When using the pipette to transfer the solutions, pull the solution off of the top of the beaker (if you pull from the bottom and there are granules of salt that had not completely dissolved, gravity will pull them to the bottom of the graduated cylinder and mix your layers.).
6. Using the pipette, carefully layer 20 mL from beaker 2 on top of the 20 mL of blue liquid that is already in the grad. Add the layer by SLOWLY running the solution down the inside of the glass of the grad. Do NOT squirt the solution directly into the solution at the bottom of the cylinder.
7. Repeat for beakers 3-5.
Step 3: Final Product
The solution should remain layered as long as it is undisturbed. Place the best examples in a sunny window to leave on display. Evaporation could start to influence the layers, but then you just have an additional teaching tool.
Inevitably, some students will not follow the instructions. There is enough solution in each beaker to complete the experiment twice (50 mL of the solution but only need 20 mL of each color). Students can either restart the experiment if they made a mistake, or develop their own experiments with the remaining solutions if they did the experiment perfectly the first time.
Follow up questions include making connections to nature and an inquiry as to what other solutions/liquids might be used to recreate this layered experiment. Have fun and stay curious!
Classroom Science Contest
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    7 Discussions
    MrsHarrisTeaches
    MrsHarrisTeaches
    Question 1 year ago
    So pretty! For some reason I just want to stir it up. About how long does it stay separated nicely?
    Biodynamic
    Biodynamic
    Answer 1 year ago
    The longest I have kept the colors has been a few weeks. Temperature changes seem to make certain layers mix more quickly than others. Direct sunlight will also cause the layers to mix (probably because of the heat).
    Alex in NZ
    Alex in NZ
    1 year ago
    Ermagerd, I recognise those food colours. My mum had exactly those bottles back in the 1970s! This is a great demonstration of haloclines, but the food colouring is what made it for me :-)
    green7550
    green7550
    Question 1 year ago on Introduction
    What would be the extrapolations to nature? Love this!
    Biodynamic
    Biodynamic
    Answer 1 year ago
    I connect it to fresh water rivers running into oceans. We talk about brackish water and how the layers are mixed by wind and currents. I also connect it to different densities between warm and cold and talk about weather fronts in the atmosphere and upwelling in the oceans.
    Tami Kruse
    Tami Kruse
    1 year ago
    It actually didn’t work. I will try it again and see if it works.
    Biodynamic
    Biodynamic
    Reply 1 year ago
    The first drops of the next layer need to go really slowly. Make sure to run the solution down the inside of the glass with a pipette. Good luck!
