Raspberry Coconut Creme Pie
Introduction: Raspberry Coconut Creme Pie
Today I will show you how to make a raspberry coconut creme pie. If you enjoy this recipe please vote for this in the pie competition.
To make this pie you will need:
Pastry:
  • 1 1/2 cups plain flour
  • 125 grams unsalted butter
  • 1/3 cup caster sugar
  • 1 egg yolk
  • 1 tablespoon cold water
  • grapeseed oil (if pastry is too dry)
Creme Filling:
  • 3/4 cup sugar
  • 1/3 cup plain flour
  • 1/4 teaspoon salt
  • 4 egg yolks
  • 2 cups milk
  • 2 tablespoons butter
  • 1 1/2 teaspoons vanilla extract
  • 1/4 - 1/2 coconut
Raspberry Topping:
  • 1 cup raspberry's (fresh or frozen)
  • 3/8 cup granulated sugar
  • 1/4 cup water
  • 1/4 teaspoon vanilla extract
  • 1 teaspoon cornstarch
  • 1 tablespoon water
  • 1/2 tablespoon butter
You will also need some tools such as a food processor and cupcake holders. Feel free to use this recipe in any way you want.
Teacher Notes
Step 1: Pastry
You will need the following ingredients to make the pastry (https://www.taste.com.au):
  • 3/4 cups plain flour
  • 62 grams unsalted butter
  • 1/6 cup caster sugar
  • 1/2 tablespoon cold water
Method:
Combine flour, sugar, butter and water in a food processor. Process until mixture resembles breadcrumbs. If the pastry is dry and cracks add a small amount of grapeseed oil and repeat step 1.
Next, Place on a lightly-floured surface and knead until smooth. Refrigerate for 30 minutes.
Step 2: Creme Filling
  • To make the creme filling you will need(https://www.foodnetwork.com):
  • 3/4 cup sugar
  • 1/4 teaspoon salt
  • 4 egg yolks
  • 2 cups milk
  • 2 tablespoons butter 1
  • 1/2 teaspoons vanilla extract
  • 1/4 - 1/2 cup coconut
Method:
Firstly, in a medium saucepan, combine sugar, flour and salt. In a seperate bowl mix egg and milk. Whisk the wet ingredients into the saucepan and mix over low heat until thickened.
Remove from the stove and add the vanilla essence and coconut. Now is the time to add any variations that you want to. You could add banana, or even raspberry sauce (Next step->).
Step 3: Raspberry Topping
You will need (https://www.tastesoflizzyt.com):
1/4 cup water
1 tablespoon water
Method:
Over heat, combine 1/2 cup raspberry's and the water (excluding the 2 tablespoons) and sugar. Mix until sugar is dissolved. Heat to boil and stir. Reduce to low heat and add the vanilla.
In a cup mix cornflour and 1 tablespoons of water. Pour this into raspberry mixture and leave on medium heat for 4 minutes or until thickened.
Then remove from heat and add butter. Add the remaining raspberry's and stir.
Step 4: Baking the Pastry
You will need:
  • The pastry from step 1
  • Rolling pin
  • Pie dish
  • Circular cookie cutter
  • Small muffin tin
  • Small cupcake holders
Method:
Preheat the oven to 180 degrees Celsius (356 degrees Fahrenheit)
Divide the pastry ball into two sections. Roll one ball with a rolling pin until the diameter reaches about 30cm (11 inches). Place into pie dish and push into all edges.
Roll out the other ball, and cut into about 9 segments (depending on the size of your pie dish) using a circular cookie cutter.Place each segment into a place of a cake holder in the muffin tin and push into edges.
Step 7: Place Both pastry into oven until golden.
Step 5: Assembly
Take the mini pies out of the muffin tin and then pour raspberry sauce into the mini pies.
Pour creme sauce into the main pie and place into fridge for 1/2 hour. Then, Place the mini pies onto the top of the main pie.
When ready to serve pour raspberry sauce onto the pie.
Step 6: Enjoy!
Enjoy!
Please leave any comments below.
Pie Contest
Pie Contest
Be the First to Share
    • Dessert Speed Challenge
    • Finish It Already Speed Challenge
    • Pizza Speed Challenge 2020
