Raspberry Pi Vnc Server
In this instructable, I will be showing you how to setup your Raspberry Pi so that you can connect to it via "Remote Desktop Connection" on Windows 7 and most VNC viewers.
Why?
The Raspberry Pi Slideshow is currently mounted on a high ledge. When ever I want to add books, I need to get up with a step ladder, plug a usb stick in, take the bluetooth keyboard down and then get to work. This proved to be very inconvenient and so I decided to make my Raspberry Pi by remote desktop.
***Please note, this is written for the operating system installed by NOOBS (Rasbian)***
Step 1: What You Will Need
  1. A raspberry pi all booted up and ready to go!
  2. An ethernet cable or a wifi adapter
  3. A laptop with a VNC viewer program (e.g. TightVnc)
  4. A USB stick
Step 2: Setting Up the VNC Server
The Raspberry's built in VNC server works pretty well but by default, it is disabled.
Menu ---> Preferences ---> Raspberry Pi Configuration ---> Interfaces ---> Enable VNC.
In terminal run the following command; "vncserver"
Take note of the IP address it gives you.
If it doesn't work, keep reading, if it does, congratulations!
Go to https://www.realvnc.com/download/vnc/raspberrypi/and download the latest version of RealVNC®.
Choose DEB ARM HF
Put your download on a USB stick.
Transfer the USB stick to the Raspberry Pi and install it.
Go to the top and follow the instructions.
Step 3: Laptop Time!
Go to your VNC viewer and type in the IP address.
Press connect and you will see a login screen
Default login is
Username: pi
Password: raspberry
      • Pets Challenge
        Pets Challenge
      • Beauty Tips Contest
        Beauty Tips Contest
      • Backyard Contest
        Backyard Contest
      We're glad you want to share something with the Instructables community! However, this appears to be incomplete and perhaps missing some important information, so we have temporarily unpublished it for you. If you would like to make some changes or additions to this, please do so. Then if you would leave me a message here, we can take second look and publish this live if it is ready.
      Thanks!
      Your friendly neighborhood Instructables staff
