Reach-Hook in Minutes!
747
7
About: Chip's Wood Shop is all about rewarding and enjoyable woodworking projects and ''use what you have''solutions to make all kinds of fun and useful things. We are a participant in the Amazon Services LLC Asso...
Hanging items up high can free up space down below. Items with flexible handles can hang on hooks, but getting them down and hanging them up can be tricky. In some stockrooms, people use a hook on the end of a pole to retrieve items that are too high to reach. I found myself in need of such a hook in my garage. I looked at what I had lying around and in about 5 minutes, I had my solution. I show how in this video.
Teacher Notes
Step 1: Tools and Materials
The idea behind this was to use what I had lying around, although the links below will take you to Amazon for similar items.
Bench Vise
Hack Saw
Hanging File Folder Frame
or other steel wire, approximately 4.5 mm (3/16") Diameter
Paint Roller Extension
5/8" (16mm) diameter drill bit, bolt, dowel or curtain rod
Step 2: Form Helix
Grip the the wire in the vise about 9.5 inches from the end (the first bend in the file hanger I used) and wrap the wire around a 5/8" diameter rod 4 or 5 times. I kept going until I got to the next bend in the wire, about 12 inches away.
Step 3: Cut Off Excess
Reorient the wire in the vise so the helix is on top and cut off the remaining wire with a hack saw.
Step 4: Bend the Helix Parallel
Reorient the straight part of the wire parallel to the vise jaws. Using the rod, bend the helix around parallel with the straight part.
Step 5: Form the Hook
Grip the end of the wire in the vise. By hand, bend the helix end over, forming the hook in a "U" shape.
Step 6: Fold the End
To keep the hook from punching holes in things, round the end by folding it over. I grabbed the end in the vise, bent it down as sharp as the jaws allow, then finish folding the end by pressing it flat in with the jaws of the vise.
Step 7: Install the Hook
Thread the helix onto the threaded end of a paint roller extension and you're done! Be careful not to lift things that are so heavy that they bend the hook. I have been using mine for months and never had a problem with the hook losing its shape.
Step 8: P.S.
If you liked this project, please vote for me in the Organization Contest!
Subscribe to my YouTube channel. If you like this style of step-by-step instruction, please share with others and subscribe, so you'll be notified when I post more. If you have questions, please post them in the comments. I will try to answer and probably update the instructions, too. Read about more of my woodworking projects and tools at ChipsWoodShop.com.
    • Indoor Lighting Contest
    • Metal Contest
      Metal Contest
    • Make It Fly Challenge
    2 Discussions
