Reading Lights From Cheap USB Lamps
Introduction: Reading Lights From Cheap USB Lamps
About: Disclaimer: The author is not responsible for loss of life, limb or property. The author is not responsible for your actions. The author is not responsible for anything. In fact, the author is completely i...
I needed new reading lights for the headboard in my room. The old ones were loose and wouldn't stay in place. I had some switches and these cheapie USB lights left over from a maker club project so I decided to 3D print a holder for them.
Teacher Notes
Step 1: Printing the Case
I printed a couple of smaller USB cases for dual purpose task light / phone charging use before so it was easy enough to double up the case.
Hardest part is paying attention to the first few layers to make sure its adhered so you don't end up with a blob.... It doesn't happen too often but when it does it's usually because I'm taking pictures for instructables......
Step 2: Assembly
I designed the box with two countersunk mounting holes that would accept some #8 drywall screws.
I wired it up with some scraps of telephone wire. Then I used a little hot glue to keep the wires safe.
Step 3: Testing
For testing I used a couple of machine screws to hold it together. I used a 5V 800mA power supply salvaged from something I don't even remember. I have a crate full of these orphaned power plugs....
A really simple project but sometimes they're the best ones....
Make it Glow Contest 2018
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    4 Discussions
    Uncle Kudzu
    Uncle Kudzu
    1 year ago
    What a great idea!
    rjkorn
    rjkorn
    Reply 1 year ago
    I like the simple stuff.
    Quicks projects with an easy payoff....
    nikdo_nic
    nikdo_nic
    Tip 1 year ago
    nice idea but you should add schematic for USB (not everyone knows how to connect it)
    rjkorn
    rjkorn
    Reply 1 year ago
    Its one of those things I find hard to explain. Most of my stuff is just made without a diagram. I have to go back and make a schematic
    Something like this is simple but I've built stuff with 6 or 7 IC's without a schematic.....
