Recycled Pallets Into Cheap Bespoke Organised Wall Feature
About: Husband and Father of 3, works full time through the week but at the weekend has a passion for crafting in his converted garage/man cave unless doing family stuff :)
This is my first instructable but I have been an avid lurker on this wonderful site called Instructables for along time, I'm a keen tinkerer in my garage converted woodshop and I love to make stuff out of wood.
So, I wanted to make a quick, cheap wall feature to fill a space infront of my pc desk at home as it was a bit plain and my desk was a bit cluttered with stuff, I also wanted to spend as little as possible on this project which cost me to make around £4 as I had to buy the cans of black spray paint (£1 each)
Teacher Notes
Step 1: Tools and Bits Required
I used the below bits and bobs to create this pallet wall feature
* 2 Wood pallets
* Bag of 50mm wood screws
* Counter sink
* Wall plugs
* Philips bit and small drill bit
* Drill
* Jig saw
* Band saw
* Wood glue
* Black spray paint
* Pencil * 180 Sand paper
* Square
* Tape measure
* Bought 4 cans of black spray paint (£1 each)
Step 2: Cutting Up the Pallets for the Shelves and Back Pieces
Next, I needed to cut off the pieces of wood from the pallets by using a jig saw and then by using the band saw to square off the edges and cut off the ends with nails in - doing this gave me 10 pieces of wood of nice clean wood.
I cut 7 pieces of wood at lengths of 730mm
Then I cut 2 pieces of shelving at 680mm
The last shelf is smaller and I cut it at 400mm
I then cut 2 extra lengths of pallet wood at 700mm which I used as a backing to screw all of the 7 pieces together - screwed from the back so minimal screws showing from the front.
Step 3: Fitting the 2 Pieces of Wood to the Wall (to Screw Wall Feature Into)
I also needed 2 pieces of the pallets which I needed for later when fixing to the wall - I screwed the 2 pieces of pallett wood to the wall - 1 at the top and 1 at the bottom making sure they are level ready for me to screw the feature to the 2 pieces of wood that are fixed to the wall making it sturdy.
Step 4: Making the Head Phone Holder
I needed a place to easily place my computer headphones so I marked up a simple shape that fitted the headphones and then used my band saw to cut it out.
I then lightly sanded it down ready and drilled 2 holesfor it to be attached to the feature then for it to be sprayed.
Step 5: Making the 2 Holders for My Sword
I needed a place to put my sword as it was just sat on my desk, so by using the offcuts from the wood pallets, I marked out the shape I needed then cut 2 shapes out by using a band saw - I sanded them down lightly then sprayed them with black gloss spray.
Step 6: Making the 3 Shelves
Using the 3 pieces of wood for the that I cut earlier - these are going to be used for the 3 shelves, I wanted to round off the face edges with the band saw.
Next, I then used wood glue and screws to fix the shelves to the wall feature and did the same for the sword and headphone pieces.
I then sprayed the whole wall feature with the 4 cans of black gloss spray.
Step 7: All Fitted to the Wall..
Once the wall feature was dry, I was then ready to attach the wall feature to the 2 pieces of wood I fixed to the wall earlier by using wood screws.
I was very happy with the finish and I now have a gaming desk setup which is organised and tidier and there is a place for every thing to go.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    seamster
    7 months ago
    Hello there!
    Unfortunately you've already published this same project, and we cannot have it published twice as two separate Instructables in order to enter multiple contests.
    I've gone ahead and unpublished this for you; you may choose to delete it when convenient.
    For more information regarding the recent rule change regarding number of contests an Instructable may enter, please see this forum topic: https://www.instructables.com/topics/Important-Changes-to-Contests-May-1st/
    Instructables Community Manager
