Recycled Powder Milk Can
This is a recycled Powder milk cans, used for littler plants.
Materials:
-Powder milk Can
-soil to plants
-Transparent hose
-filter or some thing like that
-glue
-Drill
And the most important a littler Plant
Teacher Notes
Step 1: Remove Cover Cotainer
remove the plastic cover from milk can, and clean with a littler razor, if is necessary use isopropyl alcohol to make a deep clean.
Step 2: Mark the Can Length
mark every can that will be used, to establish the maximum length and to ensure the correct hose hole.
Step 3: Mark the Hose Holes
With the hose mark the can, to know the circle diameter.
Step 4: Cut the Hose to Your Length Preferences
with a scissors or razor with the hose to establish a correct length , this length will be used to separate each can between each one.
Step 5: Bonding Between Hose and Filter
Step 6: Make a Hole Into Each Can
Make a hole in each can, where the hose can be insert litter tight
Step 7: Insert the Hose Into Each Can Hole
insert every hose into each hole, and add the necessary epoxy to avoid liquid leak and wait until the epoxy dry.
Step 8: Fill With Black Soil and Insert the Plant
fill each can with black soil, if is necessary refill with unicel each can to generate a volume where the water will be after the soil is filled
Step 9: Insert Each Plant
insert seeds into the cans and cover with soil
Step 10: Fill With Water and See
fill with water each can, you can use the hose to fill the next one.
Planter Challenge
Planter Challenge
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
    3 Discussions
    Hi Hacks, to avoid the rust you need to protect vs water effect, nevertheless in this project i didn't protect
