Recycled Pop-Pop Boat
Introduction: Recycled Pop-Pop Boat
The pop-pop boat is a small toy boat, powered by steam. The twin-pipe boiler design allows the boat to propel itself with the water that it sits on as well as a candle or other small heat source. This design requires few bought materials, and is an entertaining small project.
Supplies:
Tin can
Copper Tubing
Epoxy
Boat Base
Small Candle
Tin Snips
Exact O Knife
Needle Nose Pliers
Drill
Teacher Notes
Step 1: Separate Can Into Top, Midsection, and Bottom With Exact O Knife
Using the exact o knife, remove the top and bottom of the can. The top can be discarded, but retain the bottom to serve as the bottom of the boiler. The midsection will be cut into the top of the boiler.
Step 2: Make Metal Sheet From Can Midsection
Using the exact o knife, make a cut down the length of the can. Next, bend the midsection until it is a singular sheet.
Step 3: Create Boiler Top and Bottom.
Using the tin snips, remove the exterior of the can bottom, leaving only the bowl-shaped piece. Trace this piece onto the metal sheet, and cut. This should create a bowl-shaped boiler bottom, and a flat boiler top.
Step 4: Assemble Main Boiler.
Using pliers, bend the flat boiler top so that it sits in the boiler, with a slight lip. Bend the lip over, using the pliers. This fold secures the pieces so that they can create a secure seal. Apply epoxy to the seam between the two boiler pieces, and allow to dry.
Step 5: Attach Tubing
Trace the ends of the copper tubing onto the bottom of the boiler, near to the edge. Drill the holes through the tracings, and insert tubing. Finally, epoxy around the holes to seal.
Step 6: Attach Boiler to Boat.
Trace and drill two holes for the boiler tubes. Insert the tubes so that the boiler remains level, and slightly above the boat itself. Bend the tube ends so that they face the back of the boat. Secure in place with epoxy, and let dry. Place the candle under the boiler and your boat should be seaworthy.
Step 7: Common Problem Troubleshooting
Problem: Boat sinks or is unbalanced.
Solution: Re position boiler, or replace boat hull.
Problem: Boiler leaks.
Solution: Apply more epoxy, or ensure that the epoxy is heat and water resistant.
Problem: Boiler doesn't heat enough.
Solution: Decrease boiler height over heat source.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
    audreyobscura
    audreyobscura
    8 weeks ago
    that's so neat! What a cool little project
