Introduction: Refinish Brass Hardware Yourself // Powder Coating Project
About: I'm just a dude with a shop in my basement!
If you’re anything like me, I am not a fan of polished brass and either is my fiancé. Thing gave me an idea to learn a new skill, powder coating. This is my very first powder coating project so I am sure there is better ways but either way, I am super happy with the results!
Step 1: Remove the Hardware and Anything That Can Melt
First things first, you have to remove all the hardware from the cabinets, doors and drawers. Also keep in mind that this process requires an oven that can get to 400 degrees or more. So my next step was to remove all the plastic that I thought would melt in the oven. That being said, I didn’t remove the plastic on the hinges and that worked just fine.
Step 2: Clear the Metal
After I got rid of all the plastic, the next step was to clean up all the metal, because it is brass and steel, I chose to use glass beads that wouldn’t damage the surface. I did have some peeling happening on the door handle but after powder coating, you can’t see it. This is an Eastwood medium size blast cabinet, it hooks up to your air compressor and works perfect for these kinds of things!
Step 3: Let's Add Some Color!
My favorite part, adding color and powder coating! I used a copper pipe to hang all the hinges on so that I could get an even coat of powder on the hardware. After that I baked it in the oven for 20min past “wet“. Wet is when you check on the powder after a few minutes to see if it looks wet. After that, start the timer for 15-20min at 350-400 degrees.
Step 4: Reassemble and Enjoy!
Now you get to put everything back and enjoy your hard work. For me, it took about 4hrs to do it all. Of course I got a lot more to do around the house but this was a good first step in trying to save some money. I’ve heard you can use hammer tough spray paint as well but powder coating will hold up to much more use and abuse.
Ah yeah, as always if you want to follow me Instabook or on Facegram, it's free.
