Remodeled 80s Boombox
7,054
114
19
About: Hi, I mainly like to build projects involving electronics. The devices are often not very useful, I am more focused on toys and decorative stuff.
I first had the idea for this project when I came across a similar build on hackster.io which is now also published here as an instructable. In this project they remodeled a broken 80s boombox using a Raspberry Pi and replaced all electronics except for the speakers. I am also in possession of an old 80s boombox where only one of the tape decks was broken so I planned to remodel it with the following features.
  • Keep original speakers and amplifier
  • Keep the working tape deck (because I still have some awesome old mixtapes)
  • Replace broken tape deck with Raspberry Pi and touchscreen
  • Add LEDs with spectrum analyzer feature
  • Add a high capacity rechargeable battery
Teacher Notes
Step 1: Gather Components
Here is a list of all the components I used
  • Sanyo M W200L boombox
  • Raspberry Pi 3 B+ (amazon.de)
  • 3.5" TFT touchscreen (amazon.de)
  • 20000 mAh powerbank (amazon.de)
  • 1 m WS2812b LED strip
  • Arduino Nano
  • Panel Mount Extension USB Cable (amazon.de)
  • Ground Loop Isolator (amazon.de)
  • DC - DC Boost Converter (amazon.de)
  • 2x 1.8 kOhm, 1x 4.7 kOhm resistors
  • push button switch
  • 1000 µF, ~16 V capacitor
I was lucky enough to find this beautiful boombox in the trash a while ago. It was fully working except for one of the tape decks which keeps eating the tape. The plan was to remove the broken tape deck an replace it with a Raspberry Pi and a 3.5" touchscreen which fits almost exactly in the same space. For powering everything, I first thought about using several 18650 batteries wired in parallel but then decided to just use a powerbank since it was cheaper and has the charging circuit and 3.7 V to 5 V boost converter already build-in. Make sure though that you get a power bank which can provide enough output current. My powerbank can supply 3.4 A on two separate outputs but the total output cannot be larger than 3.4 A, i.e. I have about 17 W. The boombox is rated at 12 W which is fine but the RasPi and display can draw more than 1 A. So in total I am running a bit short of battery power and noticed some voltage drops when there are current spikes, e.g. when the tape deck motor is switched on. In addition, most powerbanks have a sleep function when the drawn current is below a certain threshold. This was not a problem for me since the RasPi does always draw enough current but it is also something to take into account. Next time I will probably use 18650 batteries which can provide more current. Since the boombox is running on 7.5 V, I still needed another boost converter. A panel mount USB cable was used to have a micro USB socket on the housing for charging the power bank. The LED strip, Arduino Nano and resistors were used to build a spectrum analyzer. The capacitor is recommended to avoid current spikes when powering the LED strip and can also help to reduce humming noise in your speakers. Since I still ended up with a lot of humming noise, I also added a ground loop isolator. In addition, to the components above, I also used a lot of wire, hot glue and some 3D printed components.
Step 2: Install Volumio on RasPi
Volumio is an open source Linux distribution designed for music playback. The UI runs on a web browser, i.e. you can control it from any phone or local PC that is connected to the same network. It supports many music streaming sources like YouTube, Spotify and WebRadio. Volumio is designed to run in your local network at home but I would also like to take my boombox outside in the summer. In this case I will have to open a local WiFi hotspot with my phone for the RasPi to connect.
Volumio also has a touchscreen plugin that shows the UI on any screen connected to the RasPi itself, however, getting this to work with my display required quite a bit of work. I basically followed this tutorial but had to make some adjustments since my display runs over HDMI.
Many people recommend using a DAC such as HiFiBerry for audio output but I was quite satisfied with the audio quality coming from the audio jack on the RasPi itself. After all I was not trying to create an audiophile high quality music source.
Step 3: Making the Spectrum Analyzer
For the spectrum analyzer I glued three rows of WS2812b LED strips to the panel that was showing the radio frequency. The electronics consist of an Arduino Nano and a few resistors according to this instructable. I also added a dip switch and wrote my own arduino code which is available below. The code is based on the FFT and FastLED libraries. The dip switch can be used to alter between the spectrum analyzer mode and two different LED animations. Since the spectrum analyzer will only be connected to the audio signal of the RasPi, the animations can be used when listening to music from the tape deck. For testing, I connected the audio jack of the RasPi to the Arduino and adjusted some parameters in the code according to the noise and volume. Since the noise situation changed a lot in the final configuration I had to readjust everything later.
Step 4: Remove Old Electronics
After opening the boombox, I removed all unnecessary parts this included the AC-DC transformer, radio and broken tape deck. This left me with enough space to add all of the new components. I also cut all unnecessary cables short so that they do not act as antennas and pick up noise.
Step 5: Insert Raspi and Touchscreen
Next, I removed the plastic cover from the tape deck and carefully attached the touchscreen and RasPi using hot glue. As you can see the 3.5" screen fits almost exactly in the space of the plastic cover from the tape deck.
Step 6: Wire New Electronics
I connected everything according to the attached schematic. The audio signal from the RasPi is running through the ground loop isolator and then into the input of the removed radio. In addition, one channel is connected to the spectrum analyzer. In the picture above, the old boombox circuit, the RasPi and Arduino are all powered from a single output of the powerbank. However, as already mentioned there were some voltage drops when there was a high current demand (e.g. starting the tape deck motor, turning the volume to max) which could cause the RasPi to restart. I then connected to RasPi to one output of the power bank and the boombox amp + arduino to the second output, which alleviated the problem. I reused the former mono/stereo switch of the radio and connected it to the power line. To step up the voltage to the 7.5 V needed for the boombox a boost converter was added. For recharging, I attached a panel mount micro USB cable to the back of the housing. The powerbank was placed in a 3D printed holder and attached with hot glue. All other components were also fixed with hot glue. I tried many different grounding schemes to reduce the humming noise. In the final configuration there is still a little bit of high pitched noise present but it is not that annoying. I thought the situation could be improved by connecting the specrum analyzer before the ground loop isolator but this was not the case. Finally, everything was tested and the Arduino code was again adapted to the noise conditions. I also frosted the plastic cover of the housing with sanding paper to diffuse the light of the spectrum analyzer LEDs.
Step 7: Add 3D Printed Components
Since the missing tape deck left some empty slots where the buttons were located, I 3D printed some fake buttons and glued them to the housing with hot glue. In addition, I also 3D printed a holder for the stylus of the touchscreen and a holder for the dip switch.
Step 8: Finished!
Finally, I closed up the housing again and could enjoy the finished project. I am already looking forward to using the boombox outdoors at the next BBQ party, sadly I will have to wait until next summer for that.
If you like this instructable please vote for me in the audio contest.
Audio Contest 2018
Audio Contest 2018
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
    19 Discussions
    chuco61
    9 months ago
    how could the code be adjusted so that each strip corresponds to a low, mid and high band?
    Im thinking 3 arduino pins could control an individual strip. FFT is a little beyond my skill set.
    I absolutely love this build!
    mosiverschuco61
    Reply 9 months ago
    Thank you, I am glad that you like the build.
    In my code each strip already corresponds to a different frequency band but the strips are controlled by a single data pin. The function "calcAmp()" first calculates the amplitude for each frequency band, then "lightPixels()" lights up the corresponding LEDs. If the number of LEDs per strip or number of strips is different in your design you just need to change the variables "NUM_LEDS" (total number of LEDs), "NDOTS" (LEDs per strip) and "BANDS" (number of strips). Also the order of the LEDs for each strip may need to be changed in the function "lightPixels()".
    Funky Koval
    Question 10 months ago
    aha, and don't care about led flasher or sth, I think this is too difficult, I want only connect ZEN to the SANYO structure via his amp, and listening music and radio from CreativeZEN by SANYO speakers
    farnaFunky Koval
    Answer 10 months ago
    You should be able to remove the tape deck or radio and input the headphone jack from the MP3 player in its place. Exactly how I can't say, would have to have a schematic. The headphone output signal might not match either, but it wouldn't hurt to try.
    Funky Kovalfarna
    Reply 9 months ago
    Thank You very much for answer, I will try! Best regards!
    mosiversFunky Koval
    Hi there, your Sanyo also looks very cool. It is certainly possible to connect it to your mp3 player. If the amp of your Sanyo is still working you can connect the mp3 player to the radio input as I did. Otherwise you could just reuse the speakers and add another amp, e.g. a TPA2012 (https://www.adafruit.com/product/1552)
    Funky Kovalmosivers
    Reply 9 months ago
    Hello. Thank you very much for your suggestions and advice !! I will try!
    Advice with a new amplifier very valuable. My SAYO, after switching on, only lightly hums, nothing more, with lighting red led. The use of such a small amplifier, would also allow me to put in SANYO, a new power supply Thank you once again and best regards!
    Leomiracle
    9 months ago
    Great project, hope to see it in action soon!
    EricN19
    10 months ago
    Nice build. Also nice Bruce Cockburn playing there.
    EricN19mosivers
    Reply 10 months ago
    I was referring to the cover art like this
    iamchrismoran
    10 months ago
    Oh man this is such a great idea! My old box has a cassette and micro cassette. The belt for the regular cassette has long ago stopped working (I've owned this since 1983). I could NOT just trash it and now I have a great idea for repurposing it.
    The buttons you glued to the top. I wonder about having them be active buttons for controlling playback on the RPi... at least a pause/play/stop option.
    mosiversiamchrismoran
    Reply 10 months ago
    I agree, it would be a shame to trash an old boombox. It is certainly possible to connect some buttons to the GPIO pins of the RPi and configure them accordingly. The buttons in my boombox were directly attached to the tape deck so unfortunately, I had to remove them.
    MarcelS9
    10 months ago
    I like this - a lot. For quite a while I've been planing to do something similar using the awesome Onion Omega2 WiFi module with Bluetooth support to allow streaming from e.g. a mobile device: https://docs.onion.io/omega2-project-book-vol1/blu...
    However, where I live those 80's boom boxes are considered "vintage" and collectors are ready to shelve out top dollars. Haven't found one yet that is both decent and reasonably priced.
    ChrisS487
    10 months ago
    Dude! This is so sweet. Specially for a Generation X'er like me. Need to try to build this.
    Elvisisnotabeachboy
    10 months ago
    Love this! Preserved original function while adding function and some awesome aesthetic appeal.
    jessyratfink
    10 months ago
    I love this! The LEDs and touchscreen blend in so seamlessly. :D
    ed.darby
    10 months ago
    Great project and well written up! Voted :)
