Repair Power Supply Miele W1514, W1714, W1614, W1730 . (EDPL200-A, EDPL200-M, EDPL200-W, EDPL200)
1,988
Introduction: Repair Power Supply Miele W1514, W1714, W1614, W1730 . (EDPL200-A, EDPL200-M, EDPL200-W, EDPL200)
Special thanks to Kevin Steward for providing me valuable information.
There was no power at all on my Miele W1714. After disassembling the control board EDPL200 I noticed that IC TEA1522 was damaged and there was short on the transformer. TEA1522T is widely available but I couldn’t manage to find the transformer. Kevin Steward had the skill to rewind the transformer. If you visit his channel youtube https://www.youtube.com/watch?v=85jzYGdRY7c he provides a lot of valuable information about this board, plus how to rewind the transformer.
Here below I will provide a workaround how to restore power if there is no power on the board
1) Disassemble the washing machine
2) Remove the board
3) Check the fuse, varistor, switch.
4) Connect power supply CAUTION HIGH VOLTAGE.
5) Measure the voltage on capacitors before primary and after primary (50V, 8V and 15V).
6) If there is no 8V and 15V as on the 2 capacitors capacitors, Kevin Stewart suggests to connect 50V external power supply and try to repair the board. Continue troubleshooting as Kevin explains. If you believe you will not be able to repair the board continue to step 7. (Continue step 7 if 8V and 15V is not present)
7) Remove the SMPS transformer
8) Connect external power supply on the board. I had salvaged a power supply from an old Humax 5400 receiver which had 8V and 15V, exactly what I needed.
9) Solder the 3 cables as indicated
10) After connecting the power supply you must notice “Waterproof” “fault” on the display.
11) You must now fix the external power supply somewhere in your washing machine.
Teacher Notes
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • First Time Author Contest
    2 Discussions
    kstewart2017
    kstewart2017
    1 year ago
    Service Mode
    1. Set to Cottons with door closed.
    2. Hold Start whilst powering up.
    3. After the rapid flashes there should be a solid light.
    4. Press the Start button 3 times (for service) or 5 times (for factory) holding it down on the last push.
    kstewart2017
    What I would say, is that there is a strong possibility that the one or more of the processor I/O pins has been damaged. The processor is not cheap and it is not easy to program. I tried to see if they had used a boot loader so that a standard in circuit programmer could be used. I am not even sure if the processor has been code protected so I stopped at that point.
    The power supply fault resulted in damage to many components on the board. I think that it is probably cheaper any more likely to result in success buying a replacement board off eBay.
    Note that any of the W15 or W17 boards seem to work in any of these machines. You will need to go into the factory service menu and change the settings accordingly. This is what I have for 2 of the models. It was mainly the 5kg/6kg drum capacity that was different. I don't know what difference the flow meter setting makes either.
    Setting
    W1514
    W1714
    Water intake
    Cold
    Cold
    Max water level
    No
    No
    Flow meter
    No
    Yes
    Low water pressure
    Yes
    Yes
    Sensor rinse
    Yes
    Yes
    Allergy
    No
    No
    Country version
    EU
    EU
    Auto load control
    Yes
    Yes
    Heater rating
    2100W
    2100W
    Suds container
    5kg
    6kg
    Imbalance charts
    5kg
    6kg
    Max spin speed
    1400
    1400
    Imbalance sensor
    Tacho
    Tacho
    Time left disp
    Yes
    Yes
