Repair Steam Irons
Introduction: Repair Steam Irons
This instructions are to help to identify the problem and fix the good working of steam system.
This steam iron is not working proplerly and do not generate steam on water deposit - The lihght of steam is permanently off
The geral of this irons have the same working system and it is possible use this instrutions to other brands manufacturers
Be careful !! Be careful !! You you will do it by your own
Teacher Notes
Step 1: How Disassemble and General Safe Instructions
  1. Disconnect from power source
  2. Remove water from deposit
  3. Identifing all screws, clips and open it
Step 2: Identify Components and Working Mode
1. heat resister: work when all circuit is closed,
1.1 thermal fuse: safety fuse that melt when the other controlers faulty
1.2 thermal switch: open if base increase to 160ºC (first cold run or when finish the water inside tank )
2 Normal work: steam is generated when water is heated to more tham 100ºC , the production of steam is controled by increase of pressure inside steam tank. the pressure switch open the circuit when pressure increase
The pressure drops when steam valve is open by normal user action from iron
Step 3: Testing Components
In cold state the following components are closed and pass on continuity test with multimeter .
test continuity:
fuse: fault ( need to be replaced)
thermal switch: ok (needs funcional test)
pressure switch :ok
Step 4: Fuse Is Open - Why??
In normal work temperature not increase to 227ºC melt temperature of safety fuse.
Why it happen?? If Thermal switch do not open circuit at 160ºc and temperature increase indefenidly
Thermal Switch working test: the normal state of thermal switch is closed and it is possible to heat manualy it to verify if it is opening with multimeter in continuity test.
- Replace it with a new 160ºC thermal swicth, normaly this is the component that fail most the times , it have a mechanical life time and it is importante use one with good quality.
Step 5: Assemble All Parts and Close the Case
After fix it and assemble all parts it will work properly.
Re-fill with water and connect it to the power, water will start to heat and steam light will indicate that is now ready to work.
I hope that it's help you
Autor : Rui J M
Fix It! Contest
Fix It! Contest
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    5 Discussions
    sdancer75
    sdancer75
    8 months ago on Step 5
    Hi,
    In my case, Philips gc8260 Pressurised Steam Generator as you can see also in the service manual (https://www.manualslib.com/manual/984865/Philips-Gc8260.html?page=7#manual) there is no pressure switch. So my question is, what kind of sensor is used to control the steam production? Of course, there is a microcontroller on the control PCB but he also needs a sensor to know the steam pressure inside the boiler.
    Check also photos from a teardown a similar model.
    https://www.ifixit.com/Teardown/Philips+Pressurised+Steam+Generator+GC8220+Teardown/26948
    rmorais85
    rmorais85
    Reply 8 months ago
    I think taht steam is fully controled by thermal sensors, so they now if temperature increase to high there is no water and out them by pump. afater this need to heat by resitir to give boiling water temmperature aand maintein this..
    old like my dont have microcontroler and precise sensor like this, so thermostate have a hight delta on/off value and need to be constroled be pressure.
    sdancer75
    sdancer75
    Reply 8 months ago
    Yes, you have right. The thermistor measurements (NTC actually) controls the water pump with a microcontroller help, to fill the boiler and depending the temperature you have inside the boiler tank, the steam pressure is approximated using a standard linear XY diagram using temperature (Celsius or Fahrenheit) related with pressure (bar) ie 100C= ~0.1 bar and 158C= ~5bar
    rmorais85
    rmorais85
    Reply 1 year ago
    Thanks !!
