Replace Wildernest Latches
1,485
Introduction: Replace Wildernest Latches
About: Traveler
Over 30+ years the latches on my Wildernest Truck Camper started to die. Finally last week the lock loop popped off.
This is how I replaced the old worn out latches with Brand New high-quality latches from Amazon.
Latches available Here: http://a.co/d/f6Ucqel
Step 1: Drill Out All the Rivets
Since this is a direct replacement all you need is the correct drillbit.
WARNING: the factory rivets have steel stems. this made drilling them out particularly tricky. take your time and use a punch to drive the stem in if you get off center.
I broke one drill bit when i was doing this because I didn't realise the rivet stems were steel.
Step 2: Compare Your Pieces
I double checked that all the holes on the old pieces lined up with the new ones.
Step 3: Rivet on the New Latches
I used Aluminum stem rivets from Harbor Freight and I also used this rivet gun.
This Rivet gun sucks but with a little oil it works okay for this Job.
you can buy the rivet gun here: https://www.harborfreight.com/hand-tools/hand-rive...
Step 4: All Done!
This whole replacement Job took me about 20 minutes and Boy am I impressed with the quality of the new latches!!!
The second photo here is the packaging that the new latches came in!
I am going to go back and put a little dab of siliconcarne in each of the rivet holes just to make sure they dont leak but that's about it!
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    michaelwagenheim
    michaelwagenheim
    Question 9 months ago on Step 3
    Hi, thank you for posting this! I am having the same issue and was having trouble finding the right replacement latches.
    Question: what size rivets did you use?
    Thanks again.
