Request Sensor Data Via SMS Using Arduino and SIM900A GSM Module
About: Share Knowledge about Arduino, ESP,GSM,Basic Electronics, DIY PROJECTS, Raspberry pi
In this blog we are going to learn about how to request Sensor Data via SMS using Arduino and SIM900A GSM Module. Sending and receiving Sms's are a part function of SIM900A GSM module. Whenever we send an sms with the message state, it then replies with temperature humidity readings.
Components Required -:
The various components required foe the following setup are-:
Teacher Notes
Step 1: Making Connections/Schematics
make connections according to the given schematics -:
Arduino Uno to DH22
GPIO2===>PIN2(DATA)
5v===>PIN1(VCC)
GND===>PIN4(GND)
Arduino Uno to GSM
GPIO7==>TX
GPIO8==>RX
GND===>GND
Furthermore insert the sim card into the holder. Also it is advisable to use sim card with a prepaid plan or Unlimited SMS. Also make sure that the antenna is well connected. power the module using external 12V and 2A power supply.
Download Schematic
Step 2: Connect Arduino to PC and Upload Code
Now connect the Arduino to the PC and Upload the code. The user can also modify the code according to their requirements. Also uncomment whichever types of sensors that you are using in your setup.
Click here to Download Code
Step 3: Check Functioning of the Setup
Check functioning by sending an sms using the SIM900A GSM module. The setup will result in the temperature and humidity readings which serve as data in calculating many soil problems.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
