Resin River Table-Top
Introduction: Resin River Table-Top
We decided to make a river resin table top. Making a table is far more cost efficient than buying one. We have been thinking about using resin for quite some time now in out many projects, and we were finally able to incorporate it into the is project. The project incorporates abstract designs and is aesthetically pleasing.
Supplies:
Resin Part A
Resin Part B
Resin Dye
Wood for table top
Wood for box
Wood Glue
Rubber Gloves
Hot Glue Gun
Heat Gun/Blow Torch
Basic Shop Tools
Stirring Rod
Beaker
Clamps
Wood Stain
Air Compresser w/ hose
Step 1: Step 1: Prepping the Table
In this step, we cut out the middle section of the table. We used a bandsaw, and angled the saw table to make the wood look like a riverbed. We made many ridges and curves in the wood so that it looked realistic, like a river. After cutting, we sanded the two halves, and stained them.
Step 2: Step 2: Making the Box
In this step, we made a box. The box is meant to hold the wood when the resin is being poured in and around it. We made the box to fit the exact size of the two halves, while also leaving room in the middle to make the river. We made it out of thin quarter inch wood to make it easy to remove once the resin was dry. Using wood glue and clamps, we made the box. Once dried, we put hot glue along all of the seams so that no resin would leak out.
Step 3: Step 3: Pouring
Before mixing the resin, we used compressed air to blow all dust and particles off of the tabletop and box. We them put the wood into the box, leaving the gap in the middle empty.
Next, we mixed equal parts of the A resin with the B resin. We then dropped in 2 beads of blue dye, and mixed thoroughly. Once mixed, we gently poured the resin into the center area, while using a heat gun to remove air bubbles. We repeated this pouring process until the resin was level with the wood
**Be sure to keep the box still and level to not have any cracks or bumps.
After a 24 hour drying period, we blew off the table top and poured another coat of clear resin on top of the table, again, using the heat gun for air bubbles. We then let it dry for another 24 hours.
Step 4: Step 4: Removing Tabletop From Box
When the resin dried, it was stuck to the box as well. Using a table saw, we cut the sides of the box off of the table. We used the planer to cut the bottom of the box off. Finally, we sanded parts of the table that were still a little rough.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    seamster
    seamster
    1 year ago
    Hey, looks great!
    What kind of class lets you make stuff like this!?? I'm jealous and wish I had this opportunity back when I was in school! : )
