Restoring an Olivetti Typewriter
Introduction: Restoring an Olivetti Typewriter
I chose this, because I always wanted to use a typewriter, and maybe use it in school for essays, or something like that. I also chose this, because this typewriter was used by my grandfather, and my dad. I kind of wanted to keep the typewriter, and hand it down to my children, etc. I am sharing this, so that people can know how to restore their typewriter.
Teacher Notes
Step 1: Materials
For this Fix it project, you will need a typewriter, alcoholic cleaner, cloth or rag, typewriter ribbon, and a toothbrush.
Step 2: Cleaning the Segment
First, you are going to clean the segment part of the typewriter, with some alcoholic cleaner, and a cloth. You have to do this, because if some keys in the segment part of the typewriter are stuck, this will help them get them working again.
Step 3: Cleaning the Keys Individually
If one specific key is stuck, you have to individually clean it, by spraying more alcoholic cleaner, and wiping it with a cloth. If the key is still stuck, spray some more alcoholic cleaner, and then get in there with a toothbrush, and clean it inside, and on the outside too.
Step 4: Clean the Top Part of the Keys
After you are done with this, you are going to clean the part of the key that has the letters on it. You spray alcoholic cleaner on each and every key, and then you are going to fold a cloth over the keys. Wait about 10 seconds, then press the cloth over the keys.
Step 5: Remove Cloth
After you have done all these steps, you will remove the cloth, to reveal all the ink you have removed from the keys.
Step 6: Putting the Ribbon in the Typewriter
The next step, would be to put the ribbon in the typewriter, for it to type, and properly work. After this, test if the typewriter types. If it does, you have a working typewriter again!
Fix It! Contest
Fix It! Contest
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    8 Discussions
    Miranda Yee
    Miranda Yee
    1 year ago
    I like how you chose this project.
    CHARLIE5234
    CHARLIE5234
    1 year ago
    I like how you explain and show how to fix it, but try recording another angle so that we can see how you do it.
    24vdovin8436
    24vdovin8436
    1 year ago
    Great job! It is really cool that you restored such an old thing. It is nice that you included a video in your instructable. I would like your explanations to be more detailed though. But everything else is awesome!
    Daniel6058
    Daniel6058
    Question 1 year ago on Step 6
    Nice! I like how you are pushing yourself to fix hard stuff
    24cruz7435
    24cruz7435
    It was really cool that you decided to fix this and your whole explanation was clear. It was also great to see the video of you showing your finishing project.
    MikeR3
    MikeR3
    1 year ago
    For the Roller (platen): Remove from machine, and place it in a drill driver. Wet some 0000 steel wool with laquer thinner, and spin the roller as you move evenly up and down with the steel wool. Repeat with a soft cloth and laquer thinner.
    Comes out better than new, all the ridges removed.
    Nice. Old mechanical typewriters are really impressive machines.
