Retro-Futuristic USB Drive
7,170
154
17
Introduction: Retro-Futuristic USB Drive
Some time ago I got a USB flash drive as a gift. The case of the drive was good-looking, but, unfortunately, it starts to cause a problem with unreliable connection after several months of use. Therefore I had stopped to use that drive. Most people would probably throw such a drive to a bin, but I kept it and I decided to repair it later. And I did it. In an interesting way.
In this instructable, I describe how I made a new and original retro-futuristic USB drive from the old USB drive and a box of another scrap.
My only inspiration was the box of scrap and old electron tubes, which I saw years ago. I had no intention to follow any particular retro-futuristic style – like steampunk, teslapunk and so on.
Teacher Notes
Step 1: Material and Tools
Material
  • USB flash drive. I used an old one...
  • USB A male connector. I used a connector from a broken USB cable.
  • blue 3 mm LED. I used an old one with a narrow beam angle.
  • resistor 100 Ω
  • 7 mm hot glue gun stick
  • two plastic tubes from a glue stick
  • aluminum tape
  • copper tape
  • blank PCB
  • wires (at least AWG 28)
Material from "Garbage Collection"
  • tube made of transparent plastic
  • knob from an old radio
  • metal grid (from a small basket)
  • plastic sheet with pinholes
  • old capacitors
  • thin coated copper wire (with a diameter about 0.3 mm)
  • wire with a diameter at least 1.5 mm; preferably coated copper wire
Tools
  • soldering iron
  • hot glue gun
  • cyanoacrylate glue (aka super glue)
  • mini drill + sander (aka Dremel tool)
  • drill, drill bits
  • saw
  • small file
  • utility knife
  • pliers
  • Kapton tape
  • matt colorless paint (acrylic-based paint is OK)
  • blue and black alcohol-based permanent maker
  • alcohol (for weathering...)
Step 2: Plan
See sketch in the picture above. It should help to clarify what is going on in the next steps.
Step 3: "Datacrystal"
As soon as I got a clearer picture of the final look, I started experimenting with a 7 mm hot glue stick and LEDs. I also tried to drill a hole to the whole axis of the hot glue stick, which showed up as a good idea. You can see the result in the picture above. (It looks better in reality than in the picture.)
The trick to drilling into a hot glue stick is to set very high drilling speed and remove material by melting. I used an old 1 mm dull drill bit. The diameter of the final hole should be almost 3 mm (which is the diameter of the LED).
Resistor for the LED
Blue LED needs typically 3V @ 20 mA. USB voltage is 5V. Therefore:
R = (5V - 3V) / 0.02A = 100 Ω
Step 4: New USB Connector
In the picture above you can see bare PCB of the Flash drive. Without the whole plastic case, it didn't fit a USB slot at all. It is necessary to solder a new USB A connector anyway. (I used an old connector from a broken USB cable. I only had to remove all the plastic with a utility knife...) In the picture above you can also see USB connector pinout. Corresponding pins should be wired together... GND and +5V wires should be connected to the resistor with the LED. It should be a straightforward soldering task.
I cover the PCB with a Kapton tape and I also secure wires with hot glue after soldering.
Step 5: Body
As a basic body, I used plastic tubes from glue sticks. It could probably look better if I would use copper or brass tubes, but I didn't have any at all. At least, plastic tubes are lightweight.
The printing on the plastic tube does not need to be removed, because it will be covered with an aluminum tape later.
I cut off tubes to the right length and cut out a notch for USB A connector and also a hole for a capacitor. This capacitor has only a decorative purpose and it is not connected at all. See pictures...
Step 6: Body – Plating
I cover whole outside of the bottom and upper body with aluminum tape.
Step 7: Body – More Plating
Then I added some decoration using a copper tape. I also covered the edges of the transparent tube with this tape.
Step 8: "Datacrystal Chamber" – Separators
Between the body and the datacrystal chamber should be separators. (It would look bad without them.) They also have an important purpose: they hold the datacrystal in the axis of the chamber.
I made them from blank PCBs (FR4). First, I drilled a 7 mm holes for the datacrystal, then I removed material from margins until separators fitted the body.
Then I glued pieces of pinhole sheets to separators as a decoration.
It should be clearer from the pictures...
Step 9: "Datacrystal Chamber" – Grid Ring
As another chamber decoration I decided to add a grid ring. I used a metal grid from a basket for office supplies. I cut off the grid to the desired width, then I bent it to ring shape and then I soldered both ends together. Finally, I soldered a piece of wire (from paperclip) to the ring.
I also added some weathering using a blue alcohol-based permanent marker.
Step 10: Coils
I added a copper coil to the upper and bottom body parts close to the middle part. I used a coated copper wire with a diameter = 0.3 mm. Every end of wires I led inside the body and secured with cyanoacrylate glue.
Step 11: Clamping Wires
All three main body parts are actually held together using three thicker copper wires. (They are functional and decorative at the same time...) I placed them symmetrically around the body (every 120°).
Step 12: Upper End
As the upper end of the body I used a knob from an old radio. Mainly because it fitted perfectly and it looked quite good. I drilled a hole in the axis of the knob for another old capacitor, but it wasn't necessary...
Step 13: Bottom End
I used a piece of PCB as the bottom end of the body. I drew my initials and year on it and then I etched it. If I didn't have a PCB, I would use a piece of plastic or a washer or something ...
Step 14: Final Assembly
After I finished all the parts, it was time to put everything together. See again the sketch in the picture above...
I glued some parts together using cyanoacrylate glue or hot glue. I didn't glue the middle transparent tube to the body.
Step 15: Weathering
The main goal of this step was to reduce the newness and the metallic shine and add more personality to the drive.
I tried to make some weathering using alcohol-based permanent markers and it worked quite good. The color stayed in scratches and so on, after raw cleaning. It highlighted imperfections.
Then I coated it with matt acrylic paint. It blurred marks from the permanent markers, but at the end of the day it showed up as unexpected improvement. I did coating in three layers.
Step 16: Last Step
The last step is missing... I have wanted to make also a wooden box, but I have had no useable wood. So, I have only a raw cardboard box so far.
Anyway, I hope I inspired you :-)
Make it Glow Contest
This is an entry in the
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    17 Discussions
    agentBures
    agentBures
    9 days ago
    Teda, to muselo dát příšernou práci....
    ThummarwitshW
    ThummarwitshW
    4 weeks ago
    This is so cool. look like star wars usb drive
    throbscottle
    throbscottle
    4 weeks ago
    So cool! But there is one thing that could improve the looks... maybe... Uranium glass!
    MarPok
    MarPok
    Reply 4 weeks ago
    Thanks. Uranium glass? I've just read an article about uranium glass on Wikipedia and wow! Interesting!
    throbscottle
    throbscottle
    Reply 4 weeks ago
    There are a few projects here on Instructables where it is used to good effect. I think they light it up with a UV LED but you'd have to check.
    AlyssonR2
    AlyssonR2
    Tip 4 weeks ago
    A super looking device. I love making things out of scrap boxes - and this is a particularly fine example of a simple fix.
    The end result could pass for steampunk, Teslapunk, Cyberpunk, grunge-SF, or even tech fantasy - and all kinds of things weird and wonderful.
    A tip for this kind of project, though - if you are sure that you are not going to need to dismantle and rework it, the area around the USB plug could do with epoxy resin encapsulation in order to prevent a reoccurrance of the original problem - broken connections.
    A suggestion for a future build - replace the USB connector with some oddball connector, and then add in an obviously home-brewed adaptor to make the fantasy tech piece compatible with early 21st Century computers.
    MarPok
    MarPok
    Reply 4 weeks ago
    Thanks for your comment :). Yes, it is somehow satisfying to make something of scrap...
    I planned to use a DIN connector (DIN 5) and DIN-USB adapter originally, but I changed my mind because it would make the drive more difficult to use with a laptop.
    RobertC2
    RobertC2
    Reply 4 weeks ago
    That last bit was brilliant!
    woofman
    woofman
    4 weeks ago
    Very nicely done. Looks particularly good attached to laptop. The right angle of the USB is terrific.....great job!
    MarPok
    MarPok
    Reply 4 weeks ago
    Thank you :)
    perec3
    perec3
    4 weeks ago
    Great imagination! Thanks
    MarPok
    MarPok
    Reply 4 weeks ago
    jessyratfink
    jessyratfink
    5 weeks ago
    That is fancy!! Loved watching it come together :D
    MarPok
    MarPok
    Reply 5 weeks ago
    Alex in NZ
    Alex in NZ
    5 weeks ago
    Beautifully written instructable for an _amazing_ piece of kit. The finished piece looks incredible. Thank you for sharing your work :-)
    MarPok
    MarPok
    Reply 5 weeks ago
    That's very nice of you! I'm almost blushing :-)
    I know that there is still a lot of "room for improvement"...
