Reuse Cans for Cards With a Cricut Maker
203
Introduction: Reuse Cans for Cards With a Cricut Maker
About: Freelance writer and regular contributor of Hackspace magazine. I'm helping to set up a makerspace in Devon, England and was a director of BuildBrighton makerspace. I'm on a mission to make things we'd norm...
My boyfriend loves Coca-Cola®, so I turned one of his empty cans into a Valentine’s card. I've written the instructions for making it with a Cricut® because it can cut, score and write the card as well as cut the aluminium shapes. If you don't have access to a Cricut®, you can use scissors or other cutters such as a Sizzix® machine.
Teacher Notes
Step 1: Materials and Tools
    • Aluminium Can(s) - it's good to have some spares
    • Cricut Maker®
    • Computer with Cricut® Design Space installed
    • Cricut® LightGrip Mat
    • Cricut® Scoring Stylus
    • Cricut® Pen (I used Red - 0.4 Tip)
    • Scissors
    • A4 White Card
    • Glue (e.g Bostik or UHU® All Purpose Glue)
    Step 2: Prepare the Aluminium Cans
      Rinse the cans and leave to dry
      Cut around the top of the can with scissors
      Cut a vertical line down from the top to the bottom of the can
      Cut around the base of the can
      Spread the can out flat on the LightGrip mat. Tip: Use a scraper or brayer to apply pressure to help the can stick to the mat. You could also tape down the edges if necessary
      Safety warning: Be careful of sharp edges
      Step 3: Draw the Hearts in Cricut Design Space
        Open a New Project in Cricut® Design Space
        Go to the Shapes icon in the toolbar on the left side of the screen and insert a Heart
        With the Heart selected, drag the arrow button on the bottom right to resize it
        Create hearts of different sizes. I used 4 sizes with widths of approx. 1, 1.8, 2.5 and 3.5cm.
        Tip: The width and height resize proportionally, but you can turn this off by clicking the lock button on the bottom left
        Copy and paste the hearts to create enough for your card design. I used 1x large, 2x medium, 3x small and 7x extra small
        Click the Make It button on the top right corner of the screen
        Arrange the hearts on the virtual cutting mat so they will fit on the can
Click Continue
        Step 4: Add a Custom Setting for Aluminium Cans
        Connect the Cricut Maker® to the computer using Bluetooth or a lead
        Click Browse All Materials
        Click Material Settings
        Scroll to the bottom of the page and click New Material
        Type in a name e.g. Aluminium Can and click Save
        Choose the following settings: Cut Pressure: 325, Multi Cut: 2x, Blade Type: Fine-Point Blade
        Click Save and close the settings page
        Choose the Aluminium Can as the material
        Load the Cutting Mat with the aluminium, into the Cricut Maker®
        Set the pressure to: More
        Step 5: Cut the Hearts
        Insert the Fine-Point Blade into tool holder B
        Press the flashing Go button
        Once the machine stops cutting, unload the mat and remove the aluminium. If the blade hasn't cut all the way through, bend the aluminium slightly and peel the hearts away
        It's useful to have an extra drinks can to remake any hearts where the graphics are cut in a position that doesn't look right
        Step 6: Create the Greeting Card
          Create a new project in Cricut® Design Space
          Insert a Square from the Shapes icon toolbar
          With the square selected, unlock the proportions by clicking on the lock button on the bottom left. Resize the square so it becomes a rectangle. If you are using an envelope, make sure the card will fit. I set it to be 28 x 14 cm
          Insert a Score Line from from the Shapes icon toolbar and set the size to be the same as the height of the rectangle e.g. 14cm
          Select the Rectangle and Score Line and go to Align > Center
          With the Rectangle and Score Line still selected, click Attach at the bottom right of the screen. This tells the Cricut® to create the score line on the rectangle
          Click on the Text icon from the toolbar
          Type the message for your card in the text box that appears. Select a font from the toolbar at the top of the screen. I used a font called SignPainter
          Change the line type from Cut to Draw from the tool bar at the top of the screen
          Position the message on the Rectangle. The message should be on the right hand side of the score line in order to be on the front when the card is folded
          Select both the Rectangle and message and click Attach
          Step 7: Cut the Greeting Card
          Click Make It
          Place the A4 card on the cutting mat
          Arrange the greeting card on the virtual cutting mat so it will fit on the A4 card. Rotate the design or card if necessary
          Click Continue
          Click Browse Materials and choose Heavy Cardstock
          Set the pressure to: Default
          Click Edit Tools and select the Scoring Stylus and click Apply
          Load the Cutting mat with the card on it, into the machine
          Place the Scoring Stylus into tool holder A
          When prompted, remove the Scoring Stylus and insert the Pen
          After the card has been drawn and cut, unload the mat
          Remove the card from the mat, by placing the mat upside down on a clean surface and peeling the mat away from the card. This stops the card from curling
          Step 8: Assemble the Card
          Fold the card along the score line
          Play around with the hearts to find a design you like
          When you have decided on a design, apply glue to the back of each heart and stick it on the card
          Be the First to Share
            • Wearables Contest
              Wearables Contest
            • Fix It Contest
              Fix It Contest
            • Wearables Contest
              Wearables Contest
            4 Discussions
            poppy.oceanblue
            poppy.oceanblue
            Reply 8 hours ago
            Thank you :)
            Penolopy Bulnick
            Penolopy Bulnick
            2 days ago
            Nice card!
            For some reason my mind told me that the white card had white heart cutouts and that the can was a full sheet behind and I was seeing it through the holes so it was crazy to see you cut out the hearts from the can. :)
            poppy.oceanblue
            poppy.oceanblue
            Reply 2 days ago
            Thanks Penolopy. Now that you mention it, I can see how it could look like that :P
