River Cutting Board
Introduction: River Cutting Board
A cutting board that has an epoxy river in the middle.
Supplies:
Materials
Live bord (black walnut slab)
Food safe epoxy
Food safe sealer
Packing tape
Scrap wood (to make a mold)
Sandpaper
Epoxy coloring
Tools
Dewalt drill
Dewalt sander
Dewalt planer
Powermatic band saw
SawStop table saw
Teacher Notes
Step 1: Cut Board to Size and Make the Mold.
1. Cut your wood piece to your desired size.
2. Cut a piece of plywood for the base of your mold bigger than you think you need.
3. Make the walls 2 or 3 inches taller than your work pice.
4. Cover all sides with packing tape to make a nonstick surface so it makes it easier to remove.
5. Use silicone to fill all cracks and crevices to make watertight.
Step 2: Pouring the Epoxy
1. Seal the wood s it dose not cause bubbles and place inside of the mold with a space in the middle.
2. Mix the epoxy as the bottle tells you to. (put coloring in now)
3. Pour the epoxy in thin layers so as not to cause bubbling and discoloring.
4. Let cure completely
Step 3: Removing and Cleaning Up the Board
1. Take apart the mold and try, not to mess up the board. (Is will take a lot of force)
2. Cut off the edges to clean them up
3. Use sandpaper from a grit of 60 gradually up to 5000 to get the board flat and smooth.
Step 4:
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
