Roasted Cauliflower With Dip
Introduction: Roasted Cauliflower With Dip
This is a very simple yet delicious starter suitable for every meal basically
Teacher Notes
Step 1: The Magic Ingredients
Here are the basic ingredients for both the Cauliflower and the dip.
Another great dip option is Tehina if you like it
- Cauliflower
- Olive oil
- Coarse salt
- Sour creme
- Green onions
Step 2: Boil the Water
For the first step you need to boil some water. enough so that your cauliflower will be fully submerse in water at this stage add some slat, it is impotent to add it now otherwise the cauliflower wont taste as great.
once the water boils add the cauliflower for about 10 minutes until the stem is soft enough to easily pick in with a fork
Step 3: Prepare to Roast
Once the stem is soft pull the cauliflower from the pot and place it in a baking tray, lace it with olive oil.
There should be a small coat of oil covering every exposed part of it.
Place it in the oven preheated to 230 degrees Celius ( 446 F) or the highest possible setting your oven can provide , if you have a fire oven that is the best way to go about it.
let it stay for about 30 minutes until you start seeing brown crusting form at the top. if after 30 minutes there is no crust crank up the heat using grill setting until it forms
Step 4: The Magic Dip
For our dip, cut a few green onions in about half cm spread and mix it with the sour creme you can add half a squeezed lemon if you like. pour a little olive oil on top to add extra flavor
Step 5: Enjoy the Starter
Serve both cauliflower and dip, sprinkle some coarse salt on the cauliflower and possibly some lemon juice.
The cauliflower will easily break using a fork and dipping it just makes it taste so good
Enjoy your meal!!
Side Dishes Challenge
Be the First to Share
    • One Pot Meals Speed Challenge
    • Backyard Contest
      Backyard Contest
    • First Time Author Contest
    btma
    btma
    1 year ago
    That's look delicios :)
