Room Air Purifier
Introduction: Room Air Purifier
I made this device mainly to counter 2 main problems that I had:
  1. Air purification in my room
  2. Cost of Air purifiers that clean air
This made me search for alternatives for tackling the same problem but with a lot cheaper solution. So I thought of a not so conventional method of trying to capture particles and luckily found out on the internet that there was research and work done for the same that is, capturing particles by the use of negative ion.
There were negative ion generators available but none was trying to capture it systematically like a device or a machine. So I thought why not combine these two and try to make a cheap and wholesome air purifying equipment.
With further research, I came to know that negative ions ( arguably) have lots of positive benefits as well which made me even more fixated on going forward with the approach that I had in my mind.
Also, this is my first attempt at soldering anything so please excuse the untidy soldering work.
Benefits of negative ions supposedly include:
• freshen and purify the air
• help lift the mood
• alleviate depression including winter depression(SAD)
• eliminate most tiny particles suspended in the air (indoors)
CAUTION:
You'll be dealing with extremely high voltage here so necessary precautions should be taken which I'll list later on in the step by step guide.
Step 1: Materials Required
Working Equipments:
  • Soldering iron and solder wire
  • hot glue gun
  • 3 pin socket (if you have earthing available) / 1metre 3 core 220v ac lead
  • wire pieces
  • wire cutter
  • multimeter
Circuit components: (11 stages)
  • PCB (acrylic preffered)
  • 20 x 1mega ohm resistors. (limit output current for safety) or 2 x 10 megaohm (whatever is available)
  • 44 x diode 1N4007
  • 33 x capacitor 100nF 275V class x2 suppression.
  • standard pins for high voltage grid.
Casing Components:
  • 4 acrylic sheets for body or anything that solid enough
  • Glue
  • 2 fans with sufficient suction capacity ( use them as per your desired noise levels by reducing the supply voltage to them. This will obviously result in efficiency change but that's a trade you gotta make.)
  • 1 mesh filter ( not too dense )
  • DC supply for fans via battery
  • Double sided tape as well as normal tape (or) clamps ( I used tape here in order to be able to open it for demonstration purposes).
Optional tool (recommended) :
  • wire wrapper. ( I hurt my fingers badly wrapping those ends lol)
Step 2: Understanding the Circuit
Walton Cockroft Voltage Multiplier
Step 3: Circuit Schematic Diagram
This is a full wave rectifier circuit.
Use this as a guide while placing components on the PCB
Step 4: Making the Circuit
  1. Place the capacitor and diodes stage wise.
  2. Solder them.
  3. Then solder the resistors in series like I have if you have only 1 megaohm ones available by the output of the Walton Cockroft multiplier circuit which you just made
  4. Then take naked copper wire, insert pins to it and solder them in position.
  5. Solder this part to the output for the series of resistors.
Optional but highly recommended step:
  1. Use multimeter after every stage to check if the diodes are working or not.
  2. Also, plug in the circuit after every stage is increased to check whether the circuit is functioning as desired or not. ( use multimeter by placing one point of it in the center line and the other at input)
CAUTION:
Don't forget to discharge the capacitors after every use as mentioned earlier as well!
Repeat the discharging process twice or maybe thrice to ensure safety.
If possible, use rubber gloves while working to eliminate the possibility of getting shocks.
Step 5: How to Discharge the Circuit
Use a metal object to do it.
I used a cutter for this purpose since it's efficient at doing the job.
Step 6: Making the Casing:
  • Use acrylic sheets to create the structure
  • From cardboard (as per your dimensional requirements) create a body for the filter as well as for the fans
  • Place the fan as close to the filter as possible for maximum suction capability.
  • Create a nozzle type geometry out of cardboard on the section above filter for the air to be directed towards the filter.
Step 7: Assembly:
  • Join all the pieces via using the glue gun and also provide a protective casing for the circuit which has been attached on the outer side of the body
  • Place the nerve ending(pins) at the top of the body so that it ejects electrons in an upward direction.
Step 8: Working
This is the result obtained after switching ON the circuit for 25 ins in my less than average polluted room ( because I live in India if it's abroad you need to put it in areas of high pollution or generate pollution to test it which I can avoid since am in India lol).
You can see deposition on the needles if you zoom in.
If kept ON for prolonged time, the particles will get deposited on the needles as well as the area around it.
Tape Contest
Tape Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    9 Discussions
    CurtR
    CurtR
    7 weeks ago
    Can you explain the function and the wiring sequence of the resistors please.
    ShivaanshG1
    ShivaanshG1
    Reply 7 weeks ago
    I have attached a Youtube video link in the procedure. I think that will explain the concept to you better than my verbal description.
    CurtR
    CurtR
    7 weeks ago
    How many resistor, diodes, and capacitors would be required to run the ionizer on 110v? Would it be half of the number shown in the diagram?
    ShivaanshG1
    ShivaanshG1
    Reply 7 weeks ago
    It depends on the final voltage that u want. It's a voltage multiplier circuit which means every stage increases the voltage. Also, it will work on any voltage you input, but the output will be according to the number of stages you have in your circuit.
    SahilParikh
    SahilParikh
    1 year ago
    Good project! It is also easy to implement this idea since the parts are easily available.
    seamster
    seamster
    1 year ago
    Interesting project, thank you for sharing.
    Was this created for a school assignment?
    ShivaanshG1
    ShivaanshG1
    Reply 1 year ago
    No, I made this to solve my own problem which I have regarding pollution. I am in college and this was just a fun activity I thought I could take onto and see where it goes! :)
    seamster
    seamster
    Reply 1 year ago
    Cool! Well keep it up, you're doing great. : )
    ShivaanshG1
    ShivaanshG1
    Reply 1 year ago
    Thank you! :))
