Roomba Explorer
By utilizing MATLAB and iRobot's Create2 Robot, this project will explore varying areas of an unknown location. We employed the sensors on the Robot to help maneuver a dangerous terrain. By getting photographs and video feed from a Raspberry Pi that is attached, we were able to determine the obstacles the Robot will face, and they will be classified.
Parts and Materials
For this project, you will need
-a computer
-newest version of MATLAB (MATLAB R2018b was used for this project)
- roombaInstall toolbox
-iRobot's Create2 Robot
-Raspberry Pi with Camera
Teacher Notes
Step 1: Initialization and Sensors
Before beginning any programming, we downloaded the roombaInstall toolbox, which allowed access to different components of the Robot.
Initially, we created a GUI to initialize any Robot. To do this, you need to type in the number of the Robot as an input. This will allow access to run our program to the Robot We worked on getting the Robot to maneuver through the many terrains it would encounter. We implemented the Cliff Sensors, Light Bump Sensors, and Physical Bump Sensors, by using their outputs to trip the Robot to change its speed and or direction. When any of the six Light Bump Sensors are detecting an object, the value they output will decrease, causing the speed of the Robot to decrease to avoid a full speed collision. When the Robot finally collides with an obstacle, the Physical Bump sensors will report a value greater than zero; because of this, the Robot will stop, so there will be no further collisions and more functions can be put into action. For the Cliff Sensors, they will read the brightness of the area around them. If the value is greater than 2800, we determined that the Robot would be on stable ground and safe. But, If the value is less than 800, the Cliff Sensors will be detecting a cliff, stopping immediately as not to fall off. Any value in between was determined to represent water and will cause the Robot to stop its action. By using the above sensors, the speed of the Robot is changed allowing us to better determine if there is any danger.
Below is the code (from MATLAB R2018b)
%% Initialization
dlgPrompts = {'Roomba Number'};
dlgTitle = 'Select Your Roomba';
dlgDefaults = {''};
opts.Resize = 'on';
dlgout = inputdlg(dlgPrompts,dlgTitle,1,dlgDefaults,opts) % Create window that prompts user to input their roomba number
n=str2double(dlgout{1});
r=roomba(n); % Initializes user specified Roomba %% Speed determination from Light Bump Sensors while true s=r.getLightBumpers; % get light bump sensors
lbumpout_1=extractfield(s,'left'); % takes the numerical values of the sensors and makes them more usable lbumpout_2=extractfield(s,'leftFront');
lbumpout_3=extractfield(s,'leftCenter');
lbumpout_4=extractfield(s,'rightCenter');
lbumpout_5=extractfield(s,'rightFront');
lbumpout_6=extractfield(s,'right');
lbout=[lbumpout_1, lbumpout_2, lbumpout_3, lbumpout_4, lbumpout_5, lbumpout_6] % converts values into matrix
sLbump=sort(lbout); %sorts matrix to lowest value can be extracted
lowLbump=sLbump(1); speed=.05+(lowLbump)*.005 %using lowest value, which represents close obstacles, to determine speed, higher speed when nothing detected
r.setDriveVelocity(speed,speed)
end
% Physical Bumpers
b=r.getBumpers; %Output true,false
bsen_1=extractfield(b,'left')
bsen_2=extractfield(b,'right')
bsen_3=extractfield(b,'front')
bsen_4=extractfield(b,'leftWheelDrop')
bsen_5=extractfield(b,'rightWheelDrop')
bumps=[bsen_1,bsen_2,bsen_3,bsen_4,bsen_5] tbump=sum(bums)
if tbump>0 r.setDriveVelocity(0,0)
end
% Cliff Sensors
c=r.getCliffSensors %% <800 is a cliff, >2800 safe, else water
csen_1=extractfield(c,'left')
csen_2=extractfield(c,'right')
csen_3=extractfield(c,'leftFront')
csen_4=extractfield(c,'rightFront')
cliffs=[csen_1,csen_2,csen_3,csen_4]
ordcliff=sort(cliffs)
if ordcliff(1) < 2750
if cliff<800
disp 'cliff'
else
disp 'water'
end
r.TurnAngle(45)
end
Step 2: Getting Data
After the Physical Bump Sensors are tripped, the Robot will implement its on board Raspberry Pi to take a photograph of the obstacle. After taking a photograph, using text recognition if there is text in the picture, the Robot will determine what the obstacle is and what the obstacle says.
img = r.getImage; imshow(img);
imwrite(img,'imgfromcamera.jpg')
photo = imread('imgfromcamera.jpg')
ocrResults = ocr(photo)
recognizedText = ocrResults.Text;
figure;
imshow(photo) text(220, 0, recognizedText, 'BackgroundColor', [1 1 1]);
Step 3: Finishing Mission
When the Robot determines that the obstacle is HOME, it will complete its mission and stay home. After completion of the mission, the Robot will send an e-mail alert that it has returned home, and it will send the images that it took along its trip.
% Sending E-mail
setpref('Internet','SMTP_Server','smtp.gmail.com');
setpref('Internet','E_mail','tylerreynoldsroomba@gmail.com'); % mail account to send from setpref('Internet','SMTP_Username','enter sender email'); % senders username setpref('Internet','SMTP_Password','enter sender password'); % Senders password
props = java.lang.System.getProperties; props.setProperty('mail.smtp.auth','true'); props.setProperty('mail.smtp.socketFactory.class', 'javax.net.ssl.SSLSocketFactory'); props.setProperty('mail.smtp.socketFactory.port','465');
sendmail('Enter receiving email','Roomba','Roomba has returned home!!','imgfromcamera.jpg') % mail account to send to
The Robot is then finished.
Step 4: Conclusion
The MATLAB program included is separated from the whole script that was utilized with the Robot. In the final draft, make sure to put all the code, except for the initialization step, into a while loop to make sure that the bumpers are constantly running. This program can be edited to suit the needs of the user. The configuration of our Robot is shown.
*Reminder: Do not forget that the roombaInstall toolbox is needed for MATLAB to interact with the Robot and the on board Raspberry Pi.
Be the First to Share
    • Assistive Tech Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
