Introduction: Rope Braid With Side French Hair Style
Rope Braid With Side French Hair Style Tutorial For Beginners!!!!
Simply follow these easy instructions for Rope Braid With Side French Hair Style...
Step 1: Comb Your Hair
Comb your hair to make them smooth and tangle free and make a side partition.
Step 2: Divide Into Three Section
Take a strand of hair a little above the partition, divide it into three sections.
Step 3: Start Weaving
Start weaving. The right section will cross over the middle and then the left section will cross over the middle. Now add a small amount of strand to this crossed over right strand and again weave.
Step 4: Weave Similar Fashion
Weave in a similar fashion each time adding a strand of hair to the crossed over right strand till you finish right above the ear.
Step 5: Clasp With Pins
Then make a regular braid with the hair and clasp it with a pin.
Step 6: Tie Pony
Pull all the hair to the left shoulder and tie it in a pony with a band.
Step 7: Take Small Section
Take a small section from the pony and wrap it around the band and secure with a pin.
Step 8: Make a Knot
Now take two strands from the two sides of pony and make a knot.
Step 9: Again Make a Knot
Overlap these two strands at the bottom and now add small section of hair at each side to these two strands an again make a knot.
Step 10: Adding Two Strands
Similarly go on with the length of your hair each time adding to the two strands after overlapping under the braid and secure the braid with a band.
Step 11: Remove the Pins
Now remove the pin from above braid an wind it like a coil and then secure with pins.
Step 12: Final Look
Finally add some colourful rhinestones to the hair style.
