Rover
About: iam udayakumar,working as design engineer.
this is rover
used to find out any object
Teacher Notes
Step 1: Sensors
i
This has ultrasonic sensor
temperature sensor
camera
hall effect sensor
when any object is around 4cm rover stops and take's right direction
halleffect sensor :this is used to learn ow much rotation does wheel had traveled
if battery stops solar power is turned ON.
Step 2: Halleffect Sensor
A Hall effect sensor is a transducer that varies its output voltage in response to a magnetic field. Hall effect sensorsare used for proximity switching, positioning, speed detection, and current sensing applications. In its simplest form, thesensor operates as an analog transducer, directly returning a voltage.
Step 3:
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
    Hi and welcome!
    We're glad you want to share something with the Instructables community! However, this appears to be incomplete and perhaps missing some important information, so we have temporarily unpublished it for you. If you would like to make some changes or additions to this, please do so. Then if you would leave me a message here, we can take second look and publish this live if it is ready.
    Thanks!
    Your friendly neighborhood Instructables staff
