S6 Makerspace (Distance Alarm)
Introduction: S6 Makerspace (Distance Alarm)
We did a Distance Sensor, that buzzes when anything is 15 cm close to the Distance Sensor, the use of our project is when you need privacy on your room, when someone enter your room, the buzzer is going to Buzz.
Teacher Notes
Step 1: Add the Coding on the Arduino Board
Coding:
int duration:
int distance:
int const trigPin = 9;
int const echoPin = 10;
int buzzer = 2;
void setup( ){
pinMode(trigPin , OUTPUT);
pinMode( echoPin , INPUT);
pinMode( buzzer , OUTPUT);
void loop( ){ digitalWrite(trigPin, HIGH); delay(2);
digitalWrite(trigPin, LOW);
duration = pulseIn (echoPin , HIGH);
distance = (duration * 0.034)/2; if(distance < 15){ digitalWrite(2, HIGH);
else{ digitalWrite(2, LOW);
Step 2: Materials Used:
- An Arduino Board
- A Buzzer (5-Volt)
- A Distance Sensor
- 6 Female & 6 Male Wires
- The Arduino Programs
Step 3: Copy the Image Below Using the Correct Materials
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
