ULTRASONIC Patent
Alternative use of 2 hc-sr04
Transmitter the one and receiver the other
Alternative-to-electromagnetic-switch-ULTRASOUND-TRIGGER
Alternative to electromagnetic signal-ULTRASOUND TRIGGER THAT ACTIVATE THE LIGHTS-ALARM OR WHATEVER YOU WANT.
Link: https://github.com/nektarios25ma/Alternative-to-electromagnetic-signal-ULTRASOUND-TRIGGER- Trying to activate a lights or alarm, wireless with the basic arduino kit, we make a specific ultrasound signal with HC-SR04 that activate another HC-SR04 who act as receiver only , so the first will act as transmitter and the other as receiver. This was used to a school project as a part of smart city miniature and "priority" to ambulance of blocked roads with traffic lights, link to school project : https://github.com/nektarios25ma/GYMNASIO-BRYSWN2 (greece)
Supplies:
1) Arduino uno : https://grobotronics.com/funduino-uno-rev3-arduin...
2) 2 Hc-sr04 : https://grobotronics.com/ultrasonic-sensor-sr04.h...
3) Leds : 2 green ,2 red,1 yellow
https://grobotronics.com/led-diffused-5mm-prasino....
4) 1 Buzzer : https://grobotronics.com/buzzer-5v.html
5)Breadboard : https://grobotronics.com/breadboard-mini-transluc...
6)wires
7) 5 220 ohm resistors
1 Teacher Note
Step 1: Presentation to a Class
LESSON PLAN
Student age (13-17)
Stem class
Previous knowledge (basic physics -waves, electicity- and basic experience with arduino projects)
A.BE AN INVENTER (THE ART OF AN INVENTOR)
Talk about characteristics of an inventor (20 minutes)
Link: https://www.invention-info.com/characteristics-of-the-best-inventors
B. HOW TO MAKE A “PATENT”-ULTRASONIC REMOTE CONTROL - BY A MODIFIED ELECTRONIC DEVICE
1) UNDERSTANTING THE HC-SR04-MAKING THE BASIC DISTUNCE DETECTION CIRCUIT (1-2 HOURS)
TUTORIAL: https://create.arduino.cc/projecthub/Isaac100/getting-started-with-the-hc-sr04-ultrasonic-sensor-036380 OR https://www.instructables.com/id/Distance-Detector-1/
OPTIONAL USE THE PRESENTATION (POWER POINT)
2) UNDERSTANTING OUR NEEDS-ACTIONS
First we need a transmitter that produces a signal constantly-see this instructable (20 minutes)
Second we need a receiver. Talk about the modification of hc sr04, covering the receiver module in order to receive only and not transmit, and construction-code etc -see this instructable (1 hour)
Possibilities i.e. –next project https://github.com/nektarios25ma/GYMNASIO-BRYSWN2
Step 2: Transmitter
First the code of transmitter:
#define TRIGGERPIN 8
#define ECHOPIN 9
void setup()
{ pinMode(TRIGGERPIN,OUTPUT); pinMode(ECHOPIN,INPUT);
void loop()
{ digitalWrite(TRIGGERPIN,LOW); delayMicroseconds(1); digitalWrite(TRIGGERPIN,HIGH); delayMicroseconds(10); digitalWrite(TRIGGERPIN,LOW); delayMicroseconds(1);
Step 3:
Then the code of receiver:
#define echo 12
#define trigger 13
//leds and buzzers that will activate after the //signal
int ledRed = 2;
int ledOrange = 10;
int ledGreen = 9;
const int buzzer = 7;
long RECEIVER()
// THE TRIGGER SEND A SIGNAL TO ACTUALLY TURN ON THE leds and buzzer via RECEIVER
digitalWrite(trigger,LOW);
delayMicroseconds(2);
digitalWrite(trigger,HIGH); //trick to enable the receiver
long microseconds=pulseIn(echo,HIGH,100000);
return microseconds / 10;
void setup()
pinMode(echo,INPUT); \
pinMode(trigger,OUTPUT);
pinMode(ledRed, OUTPUT);
pinMode(ledOrange, OUTPUT);
pinMode(ledGreen, OUTPUT);
pinMode(buzzer,OUTPUT);
Serial.begin(9600);
void loop(){
delay(50);
Serial.println(RECEIVER()); //TEST ....IF IS WORKING-SEE THE SERIAL IF THE SENDER-TRANSMITTER //WORKS(OF COURSE ACTIVATE THE TRANSMITTER)
// IF THIS PARTICULAR ULTRASOUND DETECT WHILE TURN ON THE LEDS AND BUZZER OR WHATEVER //YOU WANT
if ( RECEIVER()>= 5 && RECEIVER()<= 29930)
digitalWrite(ledOrange, HIGH);
digitalWrite(ledGreen, HIGH);
digitalWrite(ledRed, HIGH);
tone(buzzer,1000);
delay(400);
else
digitalWrite(ledRed, LOW);
digitalWrite(ledOrange, LOW);
digitalWrite(ledGreen, LOW);
noTone(buzzer);
} //WITH NO SIGNAL THE RECEIVER WRITES ZERO
if ( RECEIVER()<= 5 )
noTone(buzzer);
Step 4: One Possible Aplication That Took Place to a Greek School
link to github : https://github.com/nektarios25ma/GYMNASIO-BRYSWN2
Sensors Contest
Sensors Contest
Be the First to Share
    • Teacher Notes Challenge
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
