SMS Door Security System Using GboardPro (GSM Cum Arduino Mega)
About: Utilizing the spare time to Make and Share DIY Electronics and IoT projects with the online maker community.
This is simple yet very useful home security alert DIY project. I made this project because of Theft in my office.
Supplies:
Hardware Required:
Software Required:
  • Arduino IDE
Teacher Notes
Step 1: Circuit Connection
The working concept of the circuit is simple:
case 1: When the magnets are close to each other, the circuit acts as a closed switch. Thus, the controller pin gets logic 0 (LOW)
case 2: When the magnets are separated, the circuit acts as an open switch. Thus, the controller pin gets logic 1 (HIGH)
Step 2: Installing Arduino IDE and GboardPro Library
Follow the Arduino official link below to install Arduino IDE on your respective OS:
On Windows -> https://www.arduino.cc/en/Guide/Windows
On Linux -> https://www.arduino.cc/en/Guide/Linux
On Mac -> https://www.arduino.cc/en/Guide/MacOS
For Windows and Mac, it is pretty straight forward to install, no major problem faced during installation. But Linux user especially beginners find some issue regarding Arduino installation of which most common serial upload error issue ("avrdude: ser_open(): can't open device" ) during the first time installation. So, I recorded a video which you may follow as shown above.
Download library file provided below. Extract and copy to Arduino -> libraries folder as in shown above.
Now, open Arduino IDE and you can check out sample codes for GSM GboardPro.
More Details about Gboard Pro available on -> https://www.itead.cc/wiki/Gboard_Pro
Step 3: Programming
For uploading code, we need USB to serial converter. I have used the cp2102 connection shown in the above images.
Pin connection:
CP2102 <--------> Gboard Pro
GND <----> GND
RXD <----> RXD
TXD <----> TXD
DTR <----> DTR
also, connect the 12V power adapter to GboardPro board for power.
If you are using same CP2102 then install the driver from the link: https://www.silabs.com/products/development-tools...
Now, select proper Arduino mega board from the tool -> boards with a suitable port as shown in image above.
Make suitable changes mentioned in code related to your number.
char number[]="+91xxxxxxxxxx"; //Destination number
Copy below code in your IDE, compile and hit upload. Code is simple self-explanatory with comments. Still, if any doubt, comment below.
Step 4: Packaging and Installation
Use a suitable box to pack the system as shown and install on the door of your home or office.
That’s it, Thanks!!
Sensors Contest
Sensors Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
