SOLAR POWER GENERATOR | Energy From Sun to Run Daily Home Appliances
Introduction: SOLAR POWER GENERATOR | Energy From Sun to Run Daily Home Appliances
About: .Founder of @PIYSocial. A Student interested more towards Digital Language. YouTuber @PIYSocial. Innovator and National Awardee in various Science Fields.Curious about how things work and interested to make ...
It is a very simple science project which is based on converting Solar Energy to usable Electric Energy. It uses the voltage regulator and nothing else. Pick all the components and set yourself ready to make an awesome project which will help you to harness full energy from the scorching sun.
Step 1: MATERIALS REQUIRED
To make this project, you will need the following major components:
1. A Voltage Regulator- LM7805 IC
2. USB Female Connector Pin
3. Solar Panel (of more than 9 volts)
You can collect all the components from your electrical shop.
Buy Solar Panel: https://tinyurl.com/y4ut5l5b
Step 2: STEP 1: Understanding the Voltage Regulator IC.
About LM7805
A LM7805 IC is a voltage regulator that outputs +5 volts. An easy way to remember the voltage output by an LM78XX series of voltage regulators is the last two digits of the number. An LM7805 ends with "05"; thus, it outputs 5 volts.
Pinout
Out of three pins of the voltage regulator,
PIN 1 is the INPUT (7 volts to 35 volts);
PIN 2 is the GROUND (GND);
PIN 3 is the OUTPUT (5 volts).
You can check more about the voltage regulator by going to the following link: https://piysocial.weebly.com/voltageregulator.html
Step 3: STEP 2: ASSEMBLING THE COMPONENTS.
At first, apply solder flux to all the pins of the IC and wire.
Then solder the positive wire of the solar panel to PIN 1 and the positive wire of the USB Female Connector to PIN 3. Solder both the negative wire, of solar panel and USB Connector to the PIN 2 (GND) of the IC.
Refer to the video and photos (number wise)
Step 4: STEP 3: YOUR PROJECT IS READY
After all the things and work, your Solar Power Generator is now fully ready. You also add a resistor in series to pin 1 if the solar panel voltage exceeds. There is also a chance of generation of heat from the IC, make sure to read our content (click here), to know how to overcome from that.
Make Sure to Visit our website to see more such exciting projects: https://piysocial.weebly.com/
Subscribe to our YouTube Channel to see the full project video: http://bit.ly/2VPHGvl
THANK YOU! I HOPE YOU WILL LIKE MY PROJECT. DON'T FORGET TO SHARE & YES, COMMENT SOME SUGGESTIONS FOR THE FUTURE PROJECTS.
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
