Sad Cat Fixer, Catch-Me Cat Toy - School Project
Introduction: Sad Cat Fixer, Catch-Me Cat Toy - School Project
Here is our product, It is a interactive toy mouse: Catch-Me Cat Toy. Here is a list of problems many cats in our society face:
  • Cats these days are becoming inactive and depressed with nothing to do
  • Most owners are busy with work or school and your cat has nothing to do.
Our Solution:
  • Today we are here to present out product, a toy that will allow your cat to become fit and have fun, called the Catch-me Cat Toy.
Details about our product:
  • Our price is $23.99 This toy runs with a 9 volt battery.
  • We will also offer a deal that provides you with the toy cat and a rechargeable battery for $28.99
  • Includes
    • built in wired joystick controller
    • Dual dc motors with gear boxes
    • 9 VOLT Alkaline Battery.
    • Arduino Processor
    • Arduino motor shield
    • Wires
    • Hand built composite base
Teacher Notes
Step 1: How It Was Built
First get Popsicle sticks and build a square base out of Popsicle sticks. Hot glue works great but wood glue probably work just as well. MAKE SURE THAT ONE SIDE IS RELATIVELY FLAT FOR MOUNTING.
Next you want to get the motor and attach it under the base and add wheels to its output shaft. If you find your wheels struggle to move, gearboxes will must be incorporated.
Next you want to Build all the circuits, arrange the wires as shown in the pictures. Your motor wires should connect to either side of the motor shield and the power supply should hook up to the front of it. The rest of the wires from the motor shield will run to the arduino.
Once that is done you want to attach hot glue the components on from the circuits and the battery as shown in the picture. Your motor shield, arduino, and power supple should be firmly attached to the base. Make sure that your wires are firmly in place too.
Now it is time to upload the code into the arduino. You can use the code provided or try and make one yourself! The code comes with its own explanation with comments.
Finally you want to test out the car with the joystick. Moving the joystick up and down should move the robot forward and backwards while moving from left to right should turn the robot.
Once it is complete and working you can add the paper cover and add a tail. This is for aesthetic reasons as well as protection for the arduino and components from damage from both the environments and a playful cat.
Step 2: Down Below Is the Link to the Code and Explanation of Each Line
Step 3:
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    2 Discussions
    Treasure Tabby
    Treasure Tabby
    5 weeks ago
    This is a great idea short of getting another cat. ;) But some cats may be afraid of new things so it may take awhile for them to get use to this idea of this being a toy . :)
