Introduction: Safety Sensor
Influences: My group had no idea what to do so we asked Jean for some ideas. We talked a lot and finally got an idea. A very common problem in school are the thefts on other person lockers.
Idea: The idea is to have a way to prevent your locker with something that isn´t a lock. The Arduino is cheaper than a lock. The educational agents will hear a loud noise if someone tries to open another person locker.
Step 1: Influences:
My group had no idea what to do so we asked Jean for some ideas. We talked a lot and finally got an idea. A very common problem in school are the thefts on other person lockers. My group decided to do a very safe locker to prevent thefts in school.
Step 2: Coding
* Ultrasonic Sensor HC-SR04 and Arduino Tutorial * * by Dejan Nedelkovski, * www.HowToMechatronics.com * */ // defines pins numbers const int trigPin = 9; const int echoPin = 10; const int buzzPin = 2; const int button1 = 3; int making =0; // defines variables long duration; int distance; void setup() { pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output pinMode(echoPin, INPUT); // Sets the echoPin as an Input pinMode(buzzPin, OUTPUT); pinMode (button1, INPUT); Serial.begin(9600); // Starts the serial communication } void loop() { // Clears the trigPin digitalWrite(trigPin, LOW); delayMicroseconds(2); // Sets the trigPin on HIGH state for 10 micro seconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds duration = pulseIn(echoPin, HIGH); // Calculating the distance distance= duration*0.034/2; // Prints the distance on the Serial Monitor Serial.print("Distance: "); Serial.println(distance); making = digitalRead(button1); Serial.println(making);if(distance>35){ digitalWrite(buzzPin, HIGH); if (making == HIGH) { digitalWrite(buzzPin, LOW); delay(10000); } } else { digitalWrite(buzzPin, LOW); } }
Step 3: How It Works
First, you need to open the door when you approximate your hand to more than 20 centimeters, the system will start to make a noise. To stop the noise there is a hidden button that can stop with the noise. The noise function is to alarm the educationals agents that there is somebody on someone's locker.
