Samsung S8 Armband 3D Printed TPU
Introduction: Samsung S8 Armband 3D Printed TPU
A short and simple instructable showing the journey of 3D printing an armband
Teacher Notes
Step 1: A 3D Printed Armband for Workout / Running / Jogging
Hello guys , greetings from India .
The inspiration for this instructable has been headphone wires comming in the way while workout and also jogging pants slipping down because of the mobile weight in the pocket .
I wanted to solve this problem by having a 3D Printed case for my Samsung S8 which I can use while running / jogging without worrying of my pants slipping down :p .
That being said I learnt modelling and designing in Fusion 360 from youtube channel Product Design Online by Kevin Kennedy , link - https://www.youtube.com/channel/UCooViVfi0DaWk_eqx... , I have been honing my designing skills by going back and forth to his youtube videos and applying it to my concept . Check his channel to get an overview of design process and learn to design / model if you are a novice.
My second inspiration in 3d printing has been Mr Greg Zumwalt , link - https://www.youtube.com/user/popzct0214 he has made some of the best 3d printed contraption and mechanism . He is great at it, check his channel for inspiration .
Step 2: Designing
After I conceptualized what I wanted , I grabbed a measuring scale and took dimensions of my samsung S8 .
Then I headed to Fusion 360 to plot the dimensions .
I wanted this design to be simple and hence the boxy features .
I originally designed two straps that were smaller and so I went back and designed straps that are longer and can be used by people with larger biceps .
Step 3: Printing
After the design process was completed it was time for printing .
So I converted the files to .stl format and sliced it in cura .
The settings are as follows -
Standard Quality- 0.28mm
Infill 20%
Filament- TPU
Filament temperature - 230 degree celcius
Bed Temp - 65 c
Support none
Printer - Ender 3
I did have to go back and forth from designing and printing to get a proper fit .
I have attached the files for 3D printing They are - samsung s8 arm band v2.stl
long belt 2.stl
armband male.stl
Step 4: Assembly
Once you have the below .stl files printed
long belt 2.stl
armband male.stl
Assemble the 2 straps by putting it in the slots on the case .
Adjust the strap that suits your bicep .
After you attach it to your arm then insert your S8 phone .
Now you can enjoy your morning jog , running without worrying about your pants ;p
Step 5: Appeal
If you find this instructable useful please do vote for me since this will be an entry for wearables contest .
I would also like to know if any of you printed this out and how was the fitting/feel (need your feedback to improve on the design and hone my skills ).
Also if you have any other mobile phone please do comment stating your phone model , based on the no of comments which has maximum people using a certain model of phone I will design the case for that model .
Looking forward for your support and love ! :D
Umair
Wearables Contest
This is an entry in the
Wearables Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
