Introduction: Scallion Pancakes
Ingredients:
- 2.5 Cups of Flour
- 1 Cup Water
- Scallions
- Salt
- Oil
- Other (Garlic, ginger, or whatever other addition you're feeling)
Step 1: Dough
First thing to do when making your scallion pancakes is to make the dough. I forget where I first got the scallion pancake recipe from, but it is very simple. It basically consists of 2.5 cups of flour and 1 cup of warm water. Mix the flour and water and kneed until you get a slightly sticky ball of dough. I've experimented with both white flour and whole wheat flour and both work with these proportions. Once you get your ball of dough, stick it in the refrigerator for a bit to let it rest.
Step 2: Scallions/Ginger/Other
While your dough is resting, chop the scallions for your scallion pancakes. I used an entire package of scallions as sold in my local supermarket (about six onions). I also added some chopped ginger root on this particular batch of scallion pancakes.
Step 3: Make the Pancake
By the time you get your scallions chopped, the dough should be done resting. Take out the dough and section it out into smaller dough-balls. Press these balls flat. You can get all fancy and use rolling pins, but I use the less technical method and use my hands. Brush the dough with oil and generously sprinkle on the scallions. I also sprinkled with salt here for added flavor. Next, roll the dough up and over the scallions. Take your scallion filled roll and spin it into a spiral. This rolling/spiraling process allows the scallions to be spread equally throughout the dough. Finally, press the dough flat once again into a pancake shape again. You should be ready to fry the pancakes at this point.
Step 4: Fry
Heat up a pan with oil on high heat. I used canola oil. Once the pan/oil is hot, add the pancakes. Just like on your standard pancakes, when the edges start to change color, the scallion pancake is ready to flip. I find each pancake cooks at somewhere between 1.5 - 2 minutes on each side. Once done, you're almost ready to eat.
Step 5: Slice & Serve
Once cooked, I slice the pancakes into quarters and serve with soy sauce for dipping.
Second Prize in the
Chinese Food Contest
Fried Food Contest
