Scrabble Tiles With Laser Cutter
Introduction: Scrabble Tiles With Laser Cutter
This is just a simple file upload for scrabble tiles which you can cut out on a laser cutter. The idea is too spray paint them copper and glue them too oaken disks which i have cut from an oaken dowel. I have included the files for both an english and a Dutch set.
Supplies:
Heavy paper stock
Laser cutter
Check out FabLAb
Teacher Notes
Step 1: Straight to Cutting
Just use this above pdf to cut out your tiles on a laser cutter.
Step 2: Gewoon Uitsnijden
Gebruik je pdf om je scrabbletegeltjes uit te snijden met een laser cutter
Step 3: Paint
I'd suggest spray painting the tiles first. I've made them attached so they wouldn't fly away while spraying. I'll upload a picture when i get to do this
Step 4: Cut Manually
Use an exacto knife to cut the tiles away from the skeleton.
Step 5: Glue
Glue the tiles to a substrate of your choice. I have cut and sanded well over a hundred of these oaken tiles by cutting down a long dowel. I'll be using these to give the tiles some structure.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    4 Discussions
    Alex in NZ
    Alex in NZ
    5 weeks ago
    These look really good. Do you have any photographs of the finished pieces?
    FarRighteous
    FarRighteous
    Reply 4 weeks ago
    I'll update the instruct able soon, meanwhile, here's a picture of the tiles. ;)
    Alex in NZ
    Alex in NZ
    Reply 4 weeks ago
    Nice! Thank you :-)
    seamster
    seamster
    5 weeks ago
    Great idea for custom game pieces : )
