Scrambler Wheel
Introduction: Scrambler Wheel
This is a Scrambler Wheel! You can spin each plate and watch as a phrase of your choice scrambles and unscrambles to reveal itself.
Teacher Notes
Step 1: Necessary Materials
1. Six plastic or paper plates
2. Scissors
3. Brass fastener
4. X-Acto knife
5. Masking tape
6. Sharpie
Optional: Sand paper
Step 2: Cut Plates to Size
Cut the first plate to size. This will be the largest plate.
Do this with all six plates, cutting each plate smaller than the one before.
Step 3: Drill a Small Hole
Using an X-Acto knife, twist a small hole into the center of all six plates. Make sure the holes are big enough to fit the brass fastener into, but not too big that the plates will have too much room to move.
Step 4: (Optional) Sand Plates' Edges
If you used paper plates, continue to the next step. However if you used plastic plates, you will most likely have rough edges you will want to file down.
To smooth the edges simply take a piece of sand paper and sand off the rough parts until the edges are as you desire
Step 5: Put Plates on Fastener
Stack the plates ontop of eachother starting biggest to smallest, making sure the holes drilled in the step before are lined up. Once you have them lined up, push the pin through all six plates.
Step 6: Secure Pin
Turn the plates over to the backside and spread the brass fastener and secure the plates.
Step 7: Design Template for Words
Trace your plate to create a template. Then pick the words or phrase you want scrambled/ revealed on the puzzle and lay them out as you would want them on the final piece.
Step 8: Create Stickers
Cut out a square of tape just big enough to write your each letter on, and tape it on top of a letter on your template. The tape should be transparent enough that you can easily trace over the letters with sharpie. Color the letter in for boldness, then cut it out.
ALTERNATIVE: If you wish, you could also use pre-made sticker letters.
Step 9: Lay Stickers on and X-Acto
Lay each sticker onto the intended spot on your plates. Once all the letters are on, take the X-Acto knife and trace each circle which will cut the stickers, allowing the wheels/plates to spin and scramble your phrase.
Step 10: Scramble and Unscramble Your Puzzle!
You're done! Now you can spin the wheels of your scrambler to both scramble and solve your puzzle.
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Looks like a lot of fun to make and use!
