Scrappy Camera Sunglasses
Introduction: Scrappy Camera Sunglasses
This is a simple way to control camera motors with only few switches.
Old camera's can be found on flea market and E-bay very cheap.I payed 10 cents for first and 2 dollars for second.
All camera's of this type pull out lenses when you turned it on,everything else can be broken,but that part need to work because they are usually made from plastic and it is almost impossible to fix it, if it is deformed.
Teacher Notes
Step 1: Dismantle the Camera
Dismantle the Camera and remove all the lenses.Any camera can do as long it is no jammed.
Just remove all the screws that are on your way!
Step 2: Cut the Glass From Old Sunglasses
Most of the cheap sunglasses are made from plastic. Just cut it on the right size.I cut little by little until it fits.
Step 3: Make the Wire Connections
I used switches from old CD-roms .Solder 1m long wire between motors and circuit so you can control it from your pocket. Connect everything like on circuit and turn one switch 180 degrees so they will move in same direction.
Step 4: Fialize
I used hot glue to keep it in place,and i paint it with black acrylic paint to hide the glue..
Enjoy...
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    4 Discussions
    Gadisha
    Gadisha
    1 year ago
    That's cool, nice idea... love the hat btw ;)
    'rakic
    'rakic
    Reply 1 year ago
    Thank you!
    That is awesome. Thanks for including a video it really helps people follow along.
    'rakic
    'rakic
    Reply 1 year ago
    You are welcome.I'm glad you like it!
