Scratch Built Paper Model Tu-144
Introduction: Scratch Built Paper Model Tu-144
the only matireal for the airliner is manila file folders, but of course you can use any thick paper. this model does not include seats nor a ditailed cockpit but the end is pleasing.
and for me it took 2 weeks for me to finish it. in the end it was three feet long!.
Supplies:
Teacher Notes
Step 1: Body Bulkheads
cut out circles freehand with an exacto blade and a bobben of thred for the patterns.
Step 2: Slide Circles Onto a Strip of Paper Strengthend at the Bottom.
Take about 7 circles, and slide them onto a peace of paper with a triangular tube running along its leangth for added streangth
Step 3: Main Body Fuselage
using an enlarged blueprint found off of google I leangthend body tubes acordingley.
Step 4: More Fuselage Building!
I then added a door between cabbin sections for a more lifelike result.
and then moved on to the tail cone
Step 5: Tailcone Done!
now with the tail cone atached wich was extremely difficult for me the fuselage looks like its taking shape.
now we cane move on to the tail fin/rudder
Step 6: Tail Fin/rudder
with the help of he blueprint I traced out the tail fin/rudder and added flap ditails and flap actuator cowling.
Step 7: Main Delta Wings
using the blueprint the wings wher made and given shape,finer apearence and streangth by adding wing spars and ribs. flap actuator cowling
Step 8: Nose and Canards
next the front nose canards wher made. this wher the toothpic comes in useful. I pushed the toothpic through the fuselage so the canards can be placed properley and symmetricaly.
Step 9: Fuselage Skin
acording to the blueprint I cut out doors and windows prior to appending the skin to the fuselage.
Step 10: Air Intakes/engine Bay
next was the air intakes it took up to 3 tries to get the intakes just how I liked them
and then befor I glued them on I the wings I cut out the place wher the wheels would retract into
and then I cut out front and main landing gear bays.
Step 11: Landing Gear
my landing gear is unfunctional just ment to look good all of the 18 wheels wher made by wrapping thin strips of paper around a pen.
Step 12: Finishing Touches
I added the landing gear in side of the landing gear bays. and added jet nozzels
Step 13: Done
with the landing gear added I drew some of the markings that I saw of of the computer and its done!
of course you can find a better way of doing sertain things.
and add some more ditails.
and even try makeing working landing gear.
and make shor you look at plenty of refrence photos.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
    3 Discussions
    Alex in NZ
    Alex in NZ
    8 weeks ago
    This is incredible. What an amazing result from just paper (and a lot of skill). Well done, and thank you for sharing your work :-)
    momshotpocket
    momshotpocket
    8 weeks ago
    thanks so much! its my very first instructable
