Introduction: Secret Locked Tissue Box
By Karena Verbitsky
In this instructable, I will show you how to make a tissue box safe that can be unlocked by your iOS device. Trick your friends, family, or intruders with this hidden space.
Step 1: Materials
Kleenex box (1)
Cardboard (metal or wood for a heavy duty box)
Needed for lock system:
Arduino (1)
Breadboard (1)
Wires
Solenoid lock (1)
Bluetooth LE breakout board (1)
Darlington transistor (1)
Red and green LEDs (1 of each)
220 ohm resistor (2)
12 V 1000+ mA power supply (1)
You may also need:
Hot glue gun
Scissors
Exacto knife (if you use metal or wood saws may be required)
Tape
Step 2: Cut the Cardboard
-I used cardboard, but I would recommend lining the box with metal or wood so that it is more durable. To start off, use your exacto knife to cut the end of the box off.
-Then measure cardboard to fit all around the inside the box to make it stronger.
-Make three layers of cardboard for the bottom and four layers for the end you cut off.
-Make sure you cut the cardboard a little shorter in length than the box.
Step 3: Glue
-Again, this step will be a bit different if you use metal. I would recommend welding the seams. For cardboard, glue the layers together.
-Glue the cardboard in the box to line it.
-Then glue the top layer of cardboard a bit lower than the top to store a few Kleenex in it.
Step 4: Hook Up the Arduino and Breadboard
Follow the steps from this DIY if you want your box to lock.
Link-
http://makezine.com/projects/controlling-a-lock-with-an-arudino-and-bluetooth-le/
Step 5: Connecting the Lock to the Box
1- cut a hole for the lock
2- tape or glue the lock to the cut off end.
3- poke hole in side to fit power chord for Arduino
4- use tape as a hinge or get a hinge for the top or side of the opening.
5- slide all the electronics into the box
Step 6: Using the Lock
You are now able to control the lock from your phone! You can now keep your valuables safe in your locked secret tissue box!
Home Automation
Hiding Places Contest
Reuse Contest
