Secret Scroll
2,648
32
7
About: I am a highly unskilled amateur wannabe workshop(er). I am the most okayest welder and woodworker, but have a lot of fun learning and trying new projects!
Ancient scrolls have always fascinated me. There are so many different styles and materials that are used. What is really important is the purpose of a scroll, which is the actual writings of those who use the scrolls as a storage device. I decided not to put my history on paper because my handwriting is horrible. Instead, I decided to put my history on a thumb drive. I made this scroll in a way that it implements the ancient way of storing information, but with a semi-modern twist.
This scroll contains:
  • 1 night light (battery operated w/ a hidden switch)
  • 1 thumb drive
  • 1 black light
  • 1 small hidden piece of paper w/ an invisible password
This project contains things that I have never done before (i.e., stained glass, gold leafing, lathing something large, gold painting, cursing). So, enjoy it; and if you make one, hopefully you can add additional features to make the project even better!
Supplies:
WOOD
LEATHER
STAIN GLASS
LEAFING/LETTERING
LIGHTS
FINISH
MISC
Teacher Notes
Step 1: GETTING IT TOGETHER
Before I start any project, I make sure I have the right tools and safety equipment. Fortunately, this project doesn't require any crazy odd-ball tools. Most of my equipment was purchased used or given to me. Some equipment would make it a lot easier and faster (i.e., drill press, better soldering iron, etc).
TOOLS
  • Rock Cutter
  • Lathe
  • Rotating Tool (Dremel)
  • Table Saw
  • Disk Sander
  • Metal Saw
  • Various Drills Bits
  • Router Bits
  • Lathe Tools
  • Glass Cutter
  • Palm Router
  • Mini Drill Press
  • Hand Drill
  • Soldering Iron
  • Forstner Bits
  • Glue Gun
  • Solder
  • 1” Belt Sander
SAFETY
  • Dust Mask
  • Shield Mask
  • Locked Door (and loud music)
Step 2: CUTTING THE WOOD
I used a 4"x 4"x13" Red Mallee wood block to cut all four sides down at a 45 degree angle. This allows for less wear on the carbide tips.
Step 3: LATHE
Cut down 2.5" on one end to make the wood fit a chuck. Proceed to make the wood round. I used a round and square carbide tip. Once complete, mark with a pencil the design you want. As the lathe was turning, I marked it with a pencil to make a desired shape.
Step 4: CUT, DRILL AND ROUTER THE SCROLL
Cut the scroll in half. Mark and drill six equally spaced holes for 5" metal rods. Drill the center of the scroll. See PDF plans to view diameter and depths.
Step 5: SAND and CARVE
Sand both ends and carve any designs at the ends of the scroll.
Step 6: LATHE TOP AND BOTTOM SECTIONS
The top and bottom of the scroll will have removable ends. I used Douglas Fir wood. See plans for the sizes I used. One end will hold the light switch and the other end will be connected to the secret hidden glass jar.
Step 7: FLASHLIGHT DISASSEMBLE
Tear apart an old flashlight. You will just need the light and battery cover.
Step 8: GOLD PAINTING / GOLD LEAFING
Cut a channel on both removable ends. Then put a wooden dowel (makeshift cotter pin). You will also need to cut a channel in both of ends of the scroll. Apply metal leaf adhesive and wait 5-20 minutes (depends on who you talk to). Apply the metal leaf and pat it down with a dry brush. Wait three days before you add a sealer.
Step 9: LIGHT ASSEMBLY
Drill out the hole in the bottom of the removable end. This is for the light switch. Use 24-gauge wire to assemble the light, the switch, and the battery. Lathe another small piece of wood to cover the bottom portion so it covers up the switch. Make sure you drill a small hole to allow the pegs to go through to switch on the light.
Step 10: PEGS
These pegs will hold the two ends securely on the scroll. Drill 4 holes on the side of each end of the main scrolls. Drill far enough in to go through the removable ends. Paint the pegs the same color as the gold lettering paint.
Step 11: DECOR
I used two different sizes of tacks for this project. Just head to Hobby Lobby and pick whatever ones you like.
Step 12: STAINED GLASS
Cut the glass with a handheld cutter and shape it with a tile or rock cutter. Copper plate all four ends of each glass plate. Attach each glass to the metal rods to add strength and to ensure the glass doesn't have pressure on them. Solder away!
Step 13: LEATHERWORK
Cut an 11" by 30" leather strip. This is to cover the center portion of the scroll. Then cut 2 strips that are 1-2 inches longer than the center circumference of the scroll. Attach two clasps to the ends. This will hold the main leather piece in place.
Step 14: PUTTING IT ALL TOGETHER
Insert the thumb drive, black light, and piece of paper (that has the invisible code on it) into the glass jar and screw it to the bottom of the removable top portion. Attach the top portion onto the main scroll and secure it with 4 pegs. Use one of the pegs to turn on and off the light located at the bottom of the scroll. Wrap the scroll with the leather and fasten it with the 2 leather straps. It is all ready to be used....only by you!
First Time Author Contest
Second Prize in the
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    7 Discussions
    djarbonaudreyobscura
    Reply 1 day ago
    Thank you, Audrey. I was hoping that it looked good to those looking at it from the website.
    seamster
    5 days ago
    Well done! It's always a pleasure to see unique and original projects like this. I hope you'll share more of your creations here. Keep it up! : )
    djarbonseamster
    Reply 1 day ago
    Thank you! I appreciate your remarks. It is exciting to be a part of the Instructables community.
    cgpacker
    7 days ago
    I want one. So cool.
    gandapacker
    7 days ago
    This looks amazing!!! Very impressive!!
