Seed Starting With the "Baggie Method."
148,183
154
70
Introduction: Seed Starting With the "Baggie Method."
About: Guy from Chicago interested in a wide range of things. Right now I'm really into Cacti And Succulents and plant propagation from seed and crossings. Check out my blog about gardening if you're bored.
Another seed starting method that can compliment or be used in place of the Ghetto Greenhouse is the "Baggie Method" if you don't have the space or desire to make seed starters out of plastic soda bottles. This method also saves you money because you don't need soil right away to start and when time comes to transplant your seedlings you can put them in an appropriate size pot. You only need a plastic sandwich bag, some seeds and a paper towel.
If you want to see more check out my blogmy blog
Step 1: Assemble Your Supplies
The kinds of seeds you can start with this method is really only limited by the variety in your collection or what you can find for sale. In this example I started citrus seeds from a citrus I got from the grocery store.
Once I was done eating this particular citrus I saved the seeds and soaked them for a day or so in a glass of water.
Step 2: Preparing the Seeds
When I was ready to sow them using the baggie method I laid them out on a napkin and moistened the napkin with a spray bottle. You want to moisten and not soak your paper napkin to avoid having your seeds get moldy. It's imperative if you're going to start citrus seeds that you sow them immediately because the longer you wait the lower your germination ratio will be.
Once I had soaked my citrus seeds overnight and set them on the paper towel which I moistened I folded the napkin in half and set it inside the plastic sandwich bag which I sealed. Then I found a very warm spot for them in my bedroom. Since it's winter I take advantage of the heater we have running and place my seed baggies near a vent. The warmth from the heating vent helps with germination especially in the middle of winter when temps aren't really optimal for seed starting.
Step 3: What It Should Look LIke
Here's how your sandwich bag, paper towel and seeds should look assembled.
Step 4: They're Growing
After a few days days I checked on my seeds and found that some had started to germinate. Once they get big enough I pot them up into little pots and let them continue to grow until they're big enough to re-pot again. Citrus like a lot of light if they're going to be grown indoors and whenever possible should be allowed to spend Spring and Summer outside.
At this point I should tell you that it will be a number of years before your citrus tree gets big enough for it to flower and fruit. But if you're a patient person or just growing for the fun of it that shouldn't be a problem for you. You can use this method to start a whole collection of citrus trees from seed to grow in your home or yard. Next time you're in the grocery store look for Key Limes, Calamondin Oranges, Kumquats, Mandarins and give them a try. If your store doesn't have a large variety of citrus available check out some of the ethnic grocery stores in your areas and discover a whole new world of fruits and veggies.
If you're not interested in growing citrus from seeds then you can use this method to start any kind of seeds that you are interested in. But I'd suggest sticking with larger seeds because they'll be easier to pick out and transplant into pots when they've sprouted. If you find that your bag retains a lot of moisture while you're waiting for your seeds to sprout open it for a few hours a day and let a little of the excess moisture evaporate.
The End.
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    70 Discussions
    chuckulz
    chuckulz
    11 years ago on Introduction
    I just save yogurt containers ; ( clean them ) ; fill with water ; drop in seeds ; keep warm ; check once a week until see roots coming out ; then put sprouts into peat plugs. Any pros / cons between this and what is here - depending on seeds ?
    mmitchell89
    mmitchell89
    Reply 3 years ago
    I haven't tried this method but I would guess that the ziploc bag helps to retain warmth as well as moisture, and the damp paper towel helps keep the seeds damp rather than wet, so if you forget to check it, it'll take longer for the sprouts to rot. But I just faced-off the ziploc baggie method vs planting directly in tiny pots of seed starting mix and I vastly preferred the ziploc baggies, so maybe with my next set of seeds, I will try your method vs the baggie method. I am new to starting seeds so still trying to figure everything out. :)
    spider36439
    spider36439
    I live in central Florida, where their used to be a lot of citrus groves, Some of my older neighbors that have worked in the industry laugh at people that plant seeds from oranges, lemons and limes, even tangerines. The fruit will produce healthy seedlings, but the fruit the seed comes from does not determine what fruit might grow from its off spring. Most will end up being grapefruit because that is what it was grafted to. It's the root stock and pollinating plant that determines what kind of fruit the tree will bear! When transplanting citrus, if all the root is not transplanted the relocated plant may or may not produce the same fruit.
    silkfool
    silkfool
    You are so right. I learned this the hard way when living in West Palm Beach. I noticed a citrus volunteer in the front yard. It wasn't in the way so I left it alone. In 5 years it was 10 feet tall and beginning to bear. OMYGOD the fruit was orange and the nastiest tasting AND smelling thing I could imagine. The neighbors wouldn't even steal them. It was hard to take the tree down because it had 4" long thorns on it and the 6" trunk was hard as a rock!! My friend said she could have saved me a lot of trouble by telling me to crush a leaf and smell it. If it smells sweet the fruit will likely be OK. The leaves on that FrankenTree smelled awful!!
    spider36439
    spider36439
    Reply 3 years ago
    Thanks for the tip. My last orange tree was blight and has to go. All we have left are Grapefruit and 1 sour orange. I hate to cut down the sour orange. it is such a beautiful tree and a few people like to make a steak marinade from them.
    NeilTheInventor
    NeilTheInventor
    Reply 3 years ago
    I am at a loss as to how anyone could possibly believe this.The rootstock has no genetic contribution to the fruit or to the seeds inside it. Seedlings are often different in quality to the parent plant, but some kinds of citrus produce more than one plant per seed. One will be a true seedling with a random genetic mix from its parents the others will be like cuttings of the fruit from which the seed came. They are clones of the parent plant and will produce fruit of equal quality.
    spider36439
    spider36439
    Reply 3 years ago
    My statement was based on conversations with people that worked in the Citrus groves for many years. All I can say to NeilTheinventor go for it. It for sure won't cost you anything to take a seed from a fruit and stick it in some dirt. The pro's say it can take ten years before you taste the first fruit raised from seed. Myself I prefer to buy from a trusted grower and wait 3 years.
    econ0003
    econ0003
    Reply 5 years ago on Introduction
    What you said is not accurate. The rootstock has nothing to do with what the seedling will be. It is the grafted variety (scion) and the pollen from the other plant.
    I would recommend growing any fruit tree from seed. You may end up with a new variety that is great. Otherwise you have a healthy tree to graft to.
    spider36439
    spider36439
    11 years ago on Step 1
    5 years from now, when you see the first fruit, Don't be surprised is you have grapefruit. The seed usually reverts back to the rootstock of the plant not the grafted fruit producing part.
    MichaelB192
    MichaelB192
    Reply 4 years ago
    I have heard stories of people planting seeds from a lime and ending up producing grapefruit. Very unexpected, but I'd personally love it.
    I grow bonsai trees, so harvesting fruit isn't really a huge priority. A surprise is always fascinating.
    MichaelB192
    MichaelB192
    Reply 4 years ago
    I would also add, if you guys are looking for fast growing citrus. Plant some "starfruit" trees. they can produce fruit as early as 14 months. They produce a LOT of fruit, and have two harvests per year.
    ChrisF25
    ChrisF25
    Actually you are incorrect. Many citrus trees are self pollinating and poly-embryonic. The poly-embryonic abilities essentially create clones of the tree. The trick is letting enough trees grow long enough so you can tell which ones are the clones and which are new varieties. In addition to this it takes between 10-12 years for fruit to grow on larger varieties. I grew a ruby red grapefruit from seed. On year 12 I got fruit, ruby red grapefruit and not some off variety. I also have a nice shade tree at 10 feet currently. Smaller fruit like Key limes only take about 4 years. Some citrus like Naval oranges, persian limes, clementine mandarines, and more have been messed with my man too much and will unlikely grow anything like the parent plant. My suggestion for such varieties is to grow a grapefruit or other healthy root system citrus and graft your favorite varity onto the rootstock.
    econ0003
    econ0003
    Seedling has nothing to do with the rootstock. It is the grafted variety.
    dildo224
    dildo224
    Reply 10 years ago on Step 1
    5 years? what about small fruit?
    pinkeyedjim
    pinkeyedjim
    Reply 11 years ago on Step 1
    And do they do that because the grapefruit have hardier roots or something?
    kitsuken
    kitsuken
    Reply 11 years ago on Introduction
    Another possibility would be if the rootstock is a hardier plant with less issues with disease and more suitable for the climate where it is being grown.
    becauseican
    becauseican
    probaby i have an apple tree in the yard of the house i moved into and the apples a bitter so i think the fruitr is from the rootstock anf the good tasting apple part of the tree died.
    cfiorante
    cfiorante
    6 years ago
    If you want your seed to sprout even faster try taking off the woody outer skin so water can get to the seed I do this and my seeds sprout faster and and I have a better germination ratio
    SaraR48
    SaraR48
    Reply 4 years ago
    I do the same thing, it makes a big difference.
    lhs1
    lhs1
    4 years ago
    A great way to see if your seeds are even eligible for germination is to drop them in a glas of water, if they do not sink they will not germinate. Great tutorial! Thanx so much
