Select Color Display for ESP32
25,751
38
21
Introduction: Select Color Display for ESP32
About: Make it yourself if you cannot buy one!
This instructables show something about selecting a color display for your ESP32 project.
The content is intended to update from time to time, I will add more details if I found new display or library update. You can also help me enrich the content by leaving comments below.
Teacher Notes
Step 1: Why Add a Display?
You can run various IoT projects prefectly without any display. But some sort of IoT project not only feed data in single direction (IoT to server), they can also gather real time information from the server or Internet for displaying.
My previous instructables, ESP32 Photo Clock is am example, it download a current minute photo from the Internet, decode the JPEG photo and display it.
There are various real time information in the server or Internet, e.g. besides room temperature, server CPU usage, weather forecast, news, stock price, alert your downloading file is done, your Youtube channel views :>
Step 2: Ok, Then Why Color Display?
Many Arduino projects use monochrome display, one of the reason is the limited resources of a MCU. 320 pixels width, 240 pixels height and 8 bits color for each RGB color channel means 230 KB for each full screen picture. But normal Arduino (ATmega328) only have 32 KB flash and it is time consuming (over a second) to read data from SD card and draw it to the color display.
However, ESP32 have changed the game. It have much faster processing power (16 MHz vs 240 MHz dual core), much more RAM (2 KB vs over 200 KB) and much more flash (32 KB vs 4 MB), so it is capable to utilize more color and higher resolution image for displaying. At the same time it is capable to do some RAM hungry process such as JPEG decoding, it is a very important feature for displaying Internet gathered information.
Step 3: Serial Peripheral Interface
Color display have many type of interfaces: Serial Peripheral Interface (SPI), 6-bits, 8-bits, 16-bits, 18-bits and also NeoPixel!
SPI dominate the hobby electronics market, most likely because of fewer wire required to connect. Most display in my drawer also only have SPI pins only, so this instructables focus on SPI display.
Note:
NeoPixel matrix is a very special type of color display. If you are interested in NeoPixel matrix display, here are some of my instructables using it:
https://www.instructables.com/id/Display-Colorful-...
https://www.instructables.com/id/ATtiny13A-NeoPixe...
https://www.instructables.com/id/IoT-LED-Matrix/
https://www.instructables.com/id/IoT-LED-Cheering-...
https://www.instructables.com/id/IoT-LED-Sign/
Step 4: Hardware & Software
There are 2 parts to be considered while selecting a color display for ESP32.
Hardware
There are various color display for hobby electronics: LCD, IPS LCD, OLED with different resolutions and different driver chips. LCD can have higher image density but OLED have better viewable angle, IPS LCD can have both. OLED have more power efficient for each light up pixel but may have burn-in problems. Color OLED operate in 14 V, it means you need a dedicate step-up circuit, but it is not a problem if you simply use with a break-out board. LCD in most case can direct operate in 3.3 V, the same operating voltage as ESP32, so you can consider not use break out board to make a slimmer product.
Software
Software support on the other side also influence your selection. You can develop ESP32 program with Arduino IDE or direct use ESP-IDF. But since ESP-IDF did not have too much display library and not much display hardware supported, so I will concentrate on Arduino display libraries only.
For the beginner, I think buying adafruit (or similar vendor) hardware and using its Arduino library can have good seamless experience (though I have no budget to try it all). TFT_eSPI library have better performance but configuration require make changes in the library folder. Ucglib and UTFT-ESP run a little bit slow but it support many hardware and it is a popular library, you can find many Arduino projects use it.
Let's start our comparison from the color display in my drawer.
Step 5: LCD ST7735
ST7735 is a very popular LCD driver model for the resolution 128x128 and 128x160. It may caused by its popularity, there are many manufacturer produce compatible product but they are not fully compatible. The initial code have some variation, the color order can be RGB or BGR and the y coordinate range also have a few pixels variation. Some library differential it by red, green or black tag but the tag color is not always true. The worst case is try the tag option one by one until you can see a fine result. The above 3rd picture is an example of using wrong tag option, you can find 3 pixels height noise bar on the top.
Step 6: LCD ST7735 Odd Size
ST7735 also have other odd size color display within the resolution range of 128x160, e.g. the above picture is a 0.96" 128x64 color display.
Step 7: IPS LCD ST7735
Thanks for the popularity of wearable gadget, I can find more small size IPS LCD in the market this year. The above picture is an 0.96" 80x160 IPS color LCD using ST7735 driver chip. As you can see in the 3rd picture, you can treat it as a 128x160 color display in code but only the middle part is actually displaying. The 4th picture is the display without breakout board, it is thin, tiny and very fit for a wearable project!
Note:
All IPS LCD have a common feature, the colors displaying are inverted, most library can simply fix it by turn on the invert option.
Step 8: OLED SSD1331
I think this is the lowest resolution color display you can find in the market, it is a 0.96" 96x64 color OLED.
OLED have a big advantage, the pixel only draw power if it light up. On the other hand, LCD back light always draw full power even you are displaying a black screen. So OLED can help save some power for the project powered by a battery.
I have tried to use it in my previous instructables:
https://www.instructables.com/id/Arduino-MINTIA-Ga...
Step 9: OLED SSD1351
This is a 1.5" 128 x 128 color OLED, this form factor is very fit for smart-watch-like wearable project. The most barrier of select this should be the price tag is around 4 times of a normal LCD.
Step 10: OLED SEPS525
This is the highest resolution color OLED I can find in hobby electronics market, it is a 1.69" 160x128 color OLED. Due to the large size breakout board, I have no idea how to use it yet.
Step 11: LCD ILI9225
It is a 2.2" 176x220 color LCD. It is relatively fewer projects using this chips and resolution. It may caused by the success of its chip family brother, ILI9341 (0.2" larger in size but have near double resolution).
Step 12: LCD ILI9341
I think ILI9341 is the most popular LCD driver chip in the hobby electronics market. In most case it is 240x320 resolution and have many screen size from 2.0" to 3.2". Some breakout board also built-in touch screen feature.
You can find many project in GitHub using this. If you are designing to buy your first LCD, a ILI9341 breakout board is a good choice.
It is also easy to find a plain LCD without breakout board in the market.
Here are some project I am using ILI9341:
https://www.instructables.com/id/Connect-LCD-to-Ra...
https://www.instructables.com/id/ESP8266-WiFi-Anal...
https://www.instructables.com/id/Breadboard-RetroP...
https://www.instructables.com/id/Portable-WiFi-Ana...
https://www.instructables.com/id/ESP32-Photo-Clock...
https://www.instructables.com/id/Battery-Powered-E...
https://www.instructables.com/id/Kids-Photo-Album-...
Step 13: IPS LCD ILI9341
This is a IPS version of 2.4" LCD using ILI9341 driver chip.
The display result is very good but the vendor not provide a breakout board option, so you need wire it yourself.
Step 14: IPS LCD ST7789
ST7789 also a common driver chip in ESP32 community. One of the reason is ESP32 official development kit using it. As same as ILI9341, ST7789 also can drive 240x320 resolution.
I have no 240x320 ST7789 display in hand, the above picture is a 1.3" 240x240 IPS color LCD.
This also the highest pixel density color display in my drawer. As same as normal LCD, it can direct operate in 3.3 V, so it is very good for making slim wearable device.
Step 15: IPS LCD HX8352C
This is a 3.0" 240x400 IPS color LCD. This is the only wide screen LCD in hobby electronics market I even seen.
Step 16: LCD ILI9486
This is a 3.5" 320x480 color LCD. This resolution is a burden for normal MCU, it require over a second to fill full screen using Ucglib.
Step 17: Software Comparison
There are many display libraries that can support various hardware. I have picked 4 of most popular Arduino library for comparison:
  • Adafruit GFX Family
  • TFT_eSPI
  • UTFT-ESP
  • Ucglib
The above picture is the hardware support list for each library.
The display speed is one of the most important thing we consider to select which library. I have chosen TFT_eSPI PDQ test for this comparison. I have made some effort to rewrite the PDQ test that can run in 4 libraries. All test will run with the same 2.8" ILI9341 LCD.
For simplify the comparison process, all display use the same connection pattern.
Here are my connection summary:
ESP32               Display
Pin 5              -> CS (Some display not breakout this pin, simply skip it)
Pin 16             -> DC
Pin 17             -> Reset
Pin 18 (VSPI CLK)  -> CLK
Pin 23 (VSPI MOSI) -> MOSI (Some display call it Din)
You may find the code at Github:
https://github.com/moononournation/Arduino_graphic...
Update
As I found TFT_eSPI is the most potential display library for ESP32 in this instructables, I have paid some effort to add support for all my display in hand. The newly added display support marked letter M in red at the above picture, here is my enhanced version:
https://github.com/moononournation/TFT_eSPI
Step 18: Adafruit GFX Family
Adafruit sell various display module in hobby electronics market and they also have very good support in software level. Their display libraries all built on a parent class called Adafruit_GFX, so I call it Adafruit GFX Family. This library generally support most Arduino hardware (also ESP32).
In Arduino Library Manager simply search "adafruit display", you can see all the family members. If you want to install it, say ILI9341, simply select "Adafruit ILI9341" and then click install. Remember also install its dependent library "Adafruit GFX Library".
Step 19: TFT-eSPI
This library method signature is very similar to Adafruit GFX, but it is tailor-made for ESP8266 or ESP32. I think the source code is optimised for ESP32, so the PDQ result is much faster than other libraries.
You can install it at Arduino Library Manager by searching "TFT-eSPI" and then click install.
Note: The most difficult part using this library is you are required to configure this library before you can use it. The configuration file is located at the library folder, it should be "Arduino/libraries/TFT_eSPI/User_setup.h" under you own documents folder. It have many comments help you to do that, please follow the comments step by step to finish the configuration. Here is my User_setup.h for ILI9341:
<p>#define ILI9341_DRIVER</p><p>#define TFT_CS   5  // Chip select control pin D8<br>#define TFT_DC   16  // Data Command control pin
#define TFT_RST  17  // Reset pin (could connect to NodeMCU RST, see next line)</p><p>#define LOAD_GLCD   // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH<br>#define LOAD_FONT2  // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4  // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6  // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7  // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8  // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
//#define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF  // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts</p><p>#define SMOOTH_FONT</p><p>#define SPI_FREQUENCY  40000000 // Maximum to use SPIFFS</p>
Step 20: Ucglib
You can install it at Arduino Library Manager by searching "Ucglib" and then click install.
Step 21: UTFT-ESP
UTFT-ESP is based on the Rinky-Dink Electronics UTFT library and added ESP8266 and ESP32 support.
You can install it by download it at Github:
https://github.com/gnulabis/UTFT-ESP
And then copy the "UTFT" folder to the Arduino library folder.
ref.: http://www.rinkydinkelectronics.com/library.php?id...
Step 22: Fine Tune SPI Frequency
ESP32 + ILI9341 can run at SPI speed 40 MHz, it require some code change at library folder. The above pictures are the fine tuned result. Here are the code change summary:
Adafruit_ILI9341
This library has already defined SPI_DEFAULT_FREQ as 40000000 for ESP32 boards. You can also change the frequency while init:
tft.begin(80000000);
TFT_eSPI
User_Setup.h
// #define SPI_FREQUENCY  27000000<br>// Actually sets it to 26.67MHz = 80/3<br>#define SPI_FREQUENCY  40000000 // Maximum to use SPIFFS
Ucglib
src/clib/ucg_dev_ic_ili9341.c
ucg_int_t ucg_dev_ic_ili9341_18(ucg_t *ucg, ucg_int_t msg, void *data)<br>{
  switch(msg)
    case UCG_MSG_DEV_POWER_UP:
      /* setup com interface and provide information on the clock speed */
      /* of the serial and parallel interface. Values are nanoseconds. */
      // return ucg_com_PowerUp(ucg, 100, 66);
      return ucg_com_PowerUp(ucg, 25, 66);
UTFT-ESP
hardware/esp/HW_ESP.h
// *** Hardwarespecific functions ***<br>void UTFT::_hw_special_init (  ) {
    if ( hwSPI ) {
        SPI.begin (  );
        // SPI.setClockDivider ( SPI_CLOCK_DIV4 );
        SPI.setFrequency(40000000);
Step 23: Comparison Round Up
Hardware
ST7735 and ILI9341 are the most popular display, this 2 are better option for the beginner. You may notice LCD have a big weakness, the viewable angle, some color lost outside the viewable angle and the screen become unreadable. If you have enough budget, OLED or IPS LCD have much better viewable angle.
Software
Speed
TFT_eSPI has best performance and Adafruit the second.
Popularity
In most case, we study how to use a code library by searching sample on the web. I have tried search four libraries keyword in Github, Adafruit is most popular and UTFT the second.
Diffcuilities
Only Adafruit GFX Family is fully configurable in user code level, other 3 libraries require some configuration in the library folder. And also Adafruit have very good portal, there are many detailed post teach you how to use their products.
Round Up
ILI9341 should be most valuable display for the beginner. Adafruit GFX Library should be most easy to use for the beginner, and since TFT_eSPI have very similar method signature, it is very easy to switch to a faster library later on.
Step 24: Optional Reading: Connect LCD Without Break Out Board
OLED require 14 V to light up the pixel so it is not easy to decouple the breakout board. On the other hand, LCD (also IPS LCD) usually operate in 3.3 V, as same as the ESP32. In most case, there are only the LED control circuit required between LCD and ESP32, i.e. a transistor and few resistors. So it relatively easy to make it.
It is very important to read the data sheet first before you decide not using breakout board. The pins layout, pin pitch size, the sample circuit connection and maximum rating all you can find in data sheet. The maximum voltage is especially important, you should sticky follow the rating or you will blow your LCD. The chip can operate in 3.3 V but LED may be 2.8 - 3.0 V so it require some electronics in the middle, most data sheet have the sample circuit. You may ask your seller send a soft copy of data sheet to you or simply Google it by the model number.
My special hint: I like to soldering a FPC cable with the same pin pitch size as the LCD to help the connection with the MCU. I have used this technique in these instructables:
Step 25: Optional Reading: Color Depth
If you read through the data sheet of the color display, you may find most of color display can support 18 bit color depth (6 bit for each RGB channel). 18 bit color depth can have a better image quality that 16 bit color depth (5 bit in red and blue channel, 6 bit for green channel). However, only Ucglib actually run at 18 bit color depth (262,144 colors), other 3 libraries all run at 16 bit color depth (65,536 colors). It is because 18 bit color depth actually require transfer 3 bytes (24 bit) of data for each pixel, it means 50% more data require to transfer and store in memory. It is one of the reason why Ucglib run slower, but it can have a better image quality.
Ref.: https://en.wikipedia.org/wiki/Color_depth
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    21 Discussions
    Tim Wilsens
    Tim Wilsens
    Question 5 weeks ago on Introduction
    Hi,
    This post is really helpful!! I am looking into possibilities to make an lcd badge patch to wear for example on your jacket.
    Do you perhaps know if there are also round lcd's which are esp32 compatible?
    We want to make as compact as possible, with a rechargable battery.
    Thanks!!
    Tim Wilsens
    Tim Wilsens
    Answer 5 weeks ago
    I now see a post with round lcd in this thread😃
    ЮрийШ
    ЮрийШ
    1 year ago
    Great article! Very interested in round displays. There are available round displays based on st7687s (128 * 128) and st7789 (240 * 240), but I have not found any information on practical use.
    shr7
    shr7
    Reply 5 months ago
    Hi, any news on st7687s? thx
    ЮрийШ
    ЮрийШ
    Reply 5 months ago
    Hello! Yes, I purchased this display from keyestudio, connected it to esp32 using this library from dfrobot. It is only necessary to consider that the pinout of the display connectors differs from dfrobot and keyestudio.
    shr7
    shr7
    Reply 5 months ago
    thx a lot
    throbscottle
    throbscottle
    Question 9 months ago
    Thanks for an informative instructable!
    I'm wanting to connect a VGA camera, the sort you find as a little module on eBay with OVPxxxx chip, to a screen such as ILxxxx family, which appears to have direct VGA input. I think it will work if I connect the camera directly with no MCU, but I'd also like to add a cross-hair to the display (for a drill targetting system). I wonder is it possible to intercept the serial video data and change individual pixels in a streaming fashion, instead of loading a whole screen into memory, changing it and passing it on? I ask because it seems to me it would need a much less powerful MCU.
    marcwolf
    marcwolf
    10 months ago
    Hi.
    Thank you so much for such a great article. I have been trying to choose the best library to use for a project that will use either a SSD1351 or a ST7735 both being 128x128. The key to my project is to be able to dump a frame buffer in to the display and then recalculate the next frame buffer. :)
    I have a problem with you comparison table. What do the numbers mean. Is a higher number better or worse when compared to other values.
    Again Many thanks for all of your work :)
    pierreclavierr
    pierreclavierr
    10 months ago on Step 7
    Bonjour merci pour ce gros projet très instructifs. J'ai acheté un mini ips (rgb)0,96"80x160 et je n'arrive pas à trouver de librairie valide, j'utilise la librairie st7735 mais j'ai deux lignes de bruit sur le côté et en bas. J'ai testé toutes les inclinaison mais c'est toujours la. Et j'aimerais bien afficher une image . bmp dessus mais je ne sais pas comment connecter mon lecteur de carte micro sd externe vue que l'écran et le lecteur utilise des pins identique. Peut-être auriez vous une solution à me proposer ?
    pierreclavierr
    pierreclavierr
    Reply 10 months ago
    Désolé il y a eu un problème je disais que j'aimerais utiliser mon écran et mon module sd en même temps mais j'ignore comment on peut faire ?
    EmanuelM35
    EmanuelM35
    1 year ago
    How do you control the display's SPI without the CS pin?
    陳亮
    陳亮
    Reply 1 year ago
    CS stands for cable select, it tell the device the SPI is active for that device. If you only have 1 device connected to the the SPI, you can simply pull down the CS pin to tell it always active. It can also simplify the code no need turn CS on and off for each message and run a little bit faster. Some breakout board not wire out CS pin and simply pull it down for you.
    stoppi71
    stoppi71
    Reply 1 year ago
    Hello!
    So the CS-defined-pin at the ESP32-board must be grounded?
    Does it have an effect, when I use the display and another I²C-sensor? Thank's for your help...
    EmanuelM35
    EmanuelM35
    Reply 1 year ago
    I bought a IPS130-v2.0 display that has CS connected to GND. I connected the LCD to a PIC24 (inferior uC than ESP32).
    I had trouble to start the display, but searching in the internet I found that I had to use SPI mode 3. The LCD started to work.
    So, basically I make a reset in the beggining (read datasheet) then next I use only SPI_DAT and SPLI_CLK. If I destroy the sequence touching with an oscilloscope, the LCD stops to understand the sequence DAT/CLK and I have to make another reset.
    Those 2 pins must be dedicated to the display, otherwise the display will get confused without the CS pin. One DAT/CLK to LCD and another DAT/CLK to I2C.
    Hope this answer your question Stoppi71.
    stoppi71
    stoppi71
    Reply 1 year ago
    Thank's Emanuel for your answer. It slowly brings light into the matter...
    stoppi71
    stoppi71
    1 year ago
    Hello! Thank's for your instruction. I want to use your 8pin ili9486 320x480 spi display with one of your presented libraries and esp32. 1.) Could you please tell me the connections between the display and the esp32 and 2.) which numbers do I have to write into the line utft myglcd (ili9486,?,?,?,?)?
    Thanks a lot for your efforts, cheers stoppi
    陳亮
    陳亮
    Reply 1 year ago
    Hi stoppi71, I am using the connection setup mentioned at step 17.
    stoppi71
    stoppi71
    Reply 1 year ago
    Thank's a lot for your help.
    coperdom
    coperdom
    Question 1 year ago on Step 14
    o esp32
    libreria....sketch...
    thanks!!
    coperdom
    coperdom
    sketch para poner fotos desde arduino en la pantalla?
