SelfCAD 3D Cannon Modeling
Introduction: SelfCAD 3D Cannon Modeling
In this tutorial we can learn basic selfcad command how to create 3d cannon fast and easy, check it out!!!
Teacher Notes
Step 1: Add Reference Image
- Click View > Reference Image
- Click add image ( in left toolbar), next you can search for cannon image
- After insert into drawing window, you also can change opacity of the image
Step 2: Sketching With 3D Sketch Tool
Click drawing and click 3d Sketch
You can use line, spline and arc command to create some sketch profile from reference image
At least we create 5 profile
Step 3: Creating 3D Tire
- We can use fill polygon and add thickness to create tire from circle and line object
- Select big circle > fill polygon > add thickness > delete top and bottom face > add thickness again
- Select small circle > fill polygon > add thickness
- Next select first circle and second circle, you can use follow path to create surface, then use add thickness to convert into 3d model
Step 4: Cannon Body
To create cannon body, we can use revolve command
Click profile > tools > revolve
Click revolve around edge, and select the edge (now it will be convert into 3d model)
Click ok to apply
Step 5: Combine All Model
You can use move and align tools to combine all model into one
Next we can join by using union tools
Step 6: Video Tutorial SelfCAD 3D Cannon
This is video tutorial selfcad how to create 3d cannon with some basic command
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Makey Makey Contest
      Makey Makey Contest
    • Instrument Contest
      Instrument Contest
