SelfCAD 3D Headset Stand
9
Introduction: SelfCAD 3D Headset Stand
In this tutorial we can learn how to create simple headset stand in selfcad with some basic command, check it out!!!
Teacher Notes
Step 1: Sketching 3D Stand
- Use reference image to attach image into drawing area
- Next you can use 3d sketch and combining between line and arc tools to create profile from image
Step 2: Convert Into 3D Model
- Select 2d profile and use fill polygons to convert into surface. You can use extrusion with amount 50 to convert into 3d surface
- After it, you can pick polygon selection and select top face, press delete button
- To convert into 3d solid, we can use add thickness with amount 7
Step 3: Creating Hole
- Now change into left views
- Click 3d Sketch > change plane into left/right > next you can draw cirlce
- Move circle into center, and use scale to change into ellipse
- Use fill polygon next extrusion with amount 200
- We can use subtract to cut main object with 3d ellipse
Step 4: VideoTutorial SelfCAD 3D Headset Stand
This is video tutorial Selfcad how to create 3d headset stand
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Makey Makey Contest
      Makey Makey Contest
    • Instrument Contest
      Instrument Contest
