SelfCAD Box Assembly Animation
This tutorial is show you how to create box assembly animation in selfcad by using animation tools
Teacher Notes
Step 1: Creating Six Rectangle Objects
- First you can drop and drag cube object into drawing area
- Next use scale tools to change scale cube object into thin
- You can copy the object and then use rotate tools to rotate
Step 2: Combine All Rectangle
After we create six rectangle object, you can use move or align tools to combine all into box
You also can move assembly box to the top, and then we can start to create animation
Step 3: Create Animation
First you can move every box object into specify axis like 100 point
Next click animation tab and start recording
Use move tools to assembly every box object with 100 point until its complete assembly
And then you can stop recording
Step 4: Editing Animation
In this steps you can editing timeline of animation object by choose the fist animation, next animation until finish
You can slide timeline by click and hold
Step 5: Video Tutorial SelfCAD Box Assembly Animation
See our video tutorial about selfcad how to create box assembly animation with some easy steps
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • Reuse Contest
      Reuse Contest
