SelfCAD Insert Command
In This tutorial i will show you how to insert command in selfcad. Insert command is used to create new inserted edge at face or polygon object
Teacher Notes
Step 1: Insert Command in Box
- To use insert command you can go to modify > insert
- Use face option and select one face at box object
- Next use insert tools and it will be create new edge on face
- You can edit face, like with extrusion or others
Step 2: Insert Command in Cylinder
- First you can use polygon options
- And select top face of polygon
- Use insert command to create new polygon
Step 3: Video Tutorial Selfcad Insert Command
This video tutorial is show you how to use selfcad insert tools
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • Reuse Contest
      Reuse Contest
