SelfCAD Modeling 3D Single Wrench
Introduction: SelfCAD Modeling 3D Single Wrench
Today we will learn how to create single wrench in 3d sketch tools with SelfCAD application. Check it out!!
Teacher Notes
Step 1: Creating Wrench 2D Sketch
- Click drawing > 3d sketch
- By using line and arc command you can create 2d sketch like image
- In this case, we create 3 profile. Profile 1, Profile 2 and Profile 3
Step 2: Convert Into 3D Model
- Select profile 1 > Click tools > Fill Polygon (its will be create surface)
- Click modify > add thickness to convert into 3d solid
- You also can do same steps to profile 2 and profile 3
- Select profile 1 and profile 2, next we can use subtract command to create hole
Step 3: Subtract With Profile 3
- First we need to copy profile 3
- Next you can put those profile in to and bottom of union object
- Finally we can use subtract command to cut union profile
Step 4: Video Tutorial SelfCAD 3D Wrench
You also can see video tutorial how to create 3d wrench with selfcad steps by steps
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Makey Makey Contest
      Makey Makey Contest
    • Instrument Contest
      Instrument Contest
