Selfcad 3D Rocket Design Tutorial
Today we can learn how to create 3d model rocket with Selfcad by using drawing tools. For the steps you can see below.
Teacher Notes
Step 1: Creating 7 Circle Objects
- Open your Selfcad account and create a project
- Click Drawing > 3D Sketch
- Click circle sketch and make sure use to/bottom plane
- Next we can create circle with coordinate and radius, set edge into 32
- For the first circle set X: 0, Y: 0 Z: 0 (enter), radius 10 (enter) and change name into 1
- For the next circle set X: 0, Y: 8 Z: 0 (enter), radius 10 (enter) and change name into 2
- Next circle set X: 0, Y: 10 Z: 0 (enter), radius 12 (enter) and change name into 3
- Next circle set X: 0, Y: 40 Z: 0 (enter), radius 16 (enter) and change name into 4
- Next circle set X: 0, Y: 62 Z: 0 (enter), radius 16 (enter) and change name into 5
- Next circle set X: 0, Y: 78 Z: 0 (enter), radius 13 (enter) and change name into 6
- Next circle set X: 0, Y: 93 Z: 0 (enter), radius 1 (enter) and change name into 7 (if circle to big you can use scale command and change X: 2 and Z:2
Step 2: Create Rocket Body
- Select all circle from 1 to 7
- Click Tools > Loft
- The object will be automatically convert into solid
- Next you can select all circle object and delete
Step 3: Create Wing Profile
- Click drawing > 3d Sketch
- Click Plane Settings > change into Precision Settings. In Snap to 4 selected (click) and check Grid Vertices (it will be 5 selected.
- Change again to Plane Settings > Change plane into Front/Back. Next you can click Front view in viewcube
- Use line command, and for first point set X: 20, Y: 0 Z:0, move cursor to right and give Length 2
- next point Length 10 (tab) and angle 100 (enter)
- next point Length 15 (tab) and angle 160 (enter)
- next point Length 15 (tab) and angle 155 (enter)
- next point Length 20 (tab) and angle 50 (enter)
- next point Length 5 (tab) and angle 226 (enter)
- Move cursor to bottom and change plane settings into Precision Settings, Now you can uncheck Gird Vertices
- Next you can connect line object into first point
Step 4: Create Wings
- Click tools > revolve and change angel 15 (ok)
- Select profile (delete)
- Next select wing > click modify > click round object > change smoothness into 3 (ok)
- Click tools > copy offsets > change position into pivot and number of copies 2 (copy)
- Now you can select all object and click Stitch and Scoop > union > apply
- We already create 3d Rocket
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
