Sensitive Night Light
You will need:
  • Arduino
  • Breadboard
  • Computer
  • LED photoresistor
  • Resistors
  • 6 LED Light
Teacher Notes
Step 1: Set Up the Wire
  1. Plug the wire at GND and the Negative ground on the breadboard
  2. Plug the negative ground of LED into the negative ground on the breadboard.
  3. Plug the resistors to the anode ground of the LED
  4. Connect the resistors 1-6 to the digital ground 2-7
  5. Put one pin of The photoresistor at the negative ground and another in the middle Of the Breadboard
  6. Connect a wire from photoresistor to the Analog In, and connect a resistor at the same row
  7. Plug the other pin of the resistor to another row, and connect another wire to the POWER 5V
Step 2: Open Your Computer and Code the Code in to Your Arduino
Download the ino. and open in the Arduino App, and connect your arduino. I got this code from https://www.instructables.com/id/Arduino-Light-Theremin/, I change the sensitive off the LED photoresistor, let it can be more easy to be trigger of opening the light.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
