Setup Blynk - Connecting Via USB
Introduction: Setup Blynk - Connecting Via USB
In this tutorial, you will learn how to setup Blynk, but over USB.
Supplies:
  • Arduino/Supported Board (Needs to be supported for USB transmission, check here)
Step 1: Setup USB in the Application
You will need Blynk for this project so that you can see the results in real time anywhere in the world. You can see how to setup Blynk in my previous tutorial. You will need to a few things when you make your application when you are choosing the connection method in the app you need to select USB.
Step 2: Setup USB in Code
The other thing you will need to change is when you go to https://examples.blynk.cc you need to select Serial or USB. You need to use this code instead.
Step 3: Run Command
The other thing you need to do after plugging in your board is to navigate to C:\Users\CYourUsername\Documents\Arduino\libraries\Blynk\scripts and run blynk-ser.bat, this will automatically locate your board/hardware and connect it to the blynk server.
IoT Challenge
IoT Challenge
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
