Introduction: Sew Useful: Handy Dandy Bottlecap Pincushion
A reuse/recycle project. With a velcro dot they live happily on the top or front of your sewing machine. They fit great into the crook of your thumb for use when pinning pieces or into an empty compartment of your embroidery thread box. A must have for any sewing kit or sewing basket. The cap keeps needles from getting lost, and pins from sticking you! Just the handiest thing you can ever make for free. Really! Everyone I've given them too wonders who they didn't have one all these years.
I use pearl cotton or the cheaper 'craft thread' you can find it next to the embroidery floss, and also can buy 24 or 36 skein bags of many colors for like $4-5 at Michaels, which is cheaper than the $1.35 a (bigger) skein costs otherwise. You can also use floss, but I don't as I like the look of the twisted ply pearl/craft thread.
You can decorate with trim or beads (I don't because I rather like them more grippable and beads hurt), but I wouldn't use beads on top, the pins might catch on them. What good is a pincushion if you can't put a pin in it?
Overall these take 30 min or less to make, time well spent and as much as I hate to say it, cute as a button!
 MATERIALS and SUPPLIES: (for one shown in this instructable)Scissors, craft thread, craft felt, fiberfill and a soda bottlecap.
Step 1: Cutting the Pieces
Hold a piece of scrap felt to the bottom of a bottlecap and trim to size, being sure to keep it even with the sides of the cap, not smaller. Round off circle as needed. Then cut a 3" square and round it into a circle. Cut a strip of felt about as wide as your cap is, and as long as it is around. Leave enough for a little overlap.
Step 2: Ball
Take the 3" circle and run a drawstring through the outside edge, draw into a little bag and stuff TIGHT. Use blunt chopstick to shove in more if needed. Tie off Securely.
What to stuff with? I recommend simple fiberfill. Stuffed extremely densely. I normally will stuff some in, close it up and tie it off enough to get my stuffing stick in and continue to stuff it once knotted. I stuff so much in the"crunch" when you poke pins in and are extremely dense.
What about what you see many selling, the tradtional Emery sand that keeps needles sharp and clean? (that little strawberry on the tomato pincushions is an emery).
I hate to disappointing many that seem to attached to this mineral, but unless you are using vintage pins you do not need a emery at all. Using emery on any pin or needle say after 1970 or so is a waste, as well as it could damage the plating of said pins and needles.
Modern pins and needles are:
1: plated and do not tarnish!
2: hardened steel and do not dull!
Just stick with fiberfill, if you stuff it full enough it is more than abrasive enough to not only HOLD the pins in but clean any magical dirt that might stick to chrome.
Step 3: Outside
Wrap rectangular piece around cap, leaving a little overhang to allow the end circle to fit in and pin the overlap, and then run a needle, if desired, into the side and through the bottom to keep it all togehter while working. (I don't need this anymore).
Start a knot on the inside bottom overlap and begin a simple whip stitch around the bottom connecting the bottom to the sides.
When you get back to where you started, go up the side seam.
Step 4: Stuff It!
Remove cap, stuff ball in. really tightnow, just your nails and fingers, shove it in tight!
Replace cap into sleeve, snug it on.
Step 5: Sew Sides to Top
Take thread again, and continue sewing the top edge to the newly placed ball.
Buttonhole or whipstitch are good, but anything works.
Step 6: Decorate!
After sewing the top, take needle and go down and out at the middle at the side seam and start embroidery accents. I like the easy as pie chain stitch for beginners for it's simplicity.
When done decorating, go back in and bring thread out the bottom. No need to knot off. Clip!
You can decorate as little or as much as you want.
Step 7: DONE!
Decorate as little or as much as you want!
Then.... Stick a pin in it's it's done!
