Shelf Made With Hinges Without Nuts and Screws
1,731
10
About: I am a product design student studying currently at National Institute of Design, Ahmedabad, Gujarat, India. I like to work with materials and explore simple mechanisms.
Hello everyone :) After making the cardboard book stand click here to view I decided to take it to a level further and discover it with some other materials. This time I explored aluminium sheet bending and rope. As I am interested in doing mechanical stuff I tried to explore making hinges without any screws or nuts or fixing.
This shelf can be hanged and used to keep flower pots, small showpieces, small utility items, a shoe rack or anything you want. This can be used as a book organizer as well when kept side ways on the table. It's use is open to explorations.
Let's get started.....
Teacher Notes
Step 1: Making the Paper Template
We start by making the paper template of the piece to be made. Print the templates given. Now using a cutter finely cut the piece from the edges of the flat template.
Step 2: Collect the Materials Required
Materials-
Aluminium Sheet -2mm thick
Rope (any preferable pattern)- 4mm thick
Tools-
Center punch
Steel ruler
Drill bit- 4mm dia
Marker/pen
Sanding files
Sand paper
Step 3: Cutting the Metal Sheet
Take the dimensions from the template made and cut 6 identical pieces from the metal sheet. I used the shearing machine for cutting the exact pieces.
Here I am using 6 pieces to get the form I want to make, but you can use whatever number of pieces you want.
Step 4: Marking the Metal Sheet
After cutting the pieces, use the paper template to mark the points to be cut, fold and holed. Prepare the markings on the sheets properly to avoid errors.
Step 5: Cutting and Drilling Holes
Now we start with cutting of the grooves on the sheets for which I used the allcut machine. After cutting the grooves, drill holes on the marked area.
Tip- Always punch the spots where you want to drill holes to avoid slipping of drill bit while drilling.
To one of the pieces I drilled two extra holes on the plane surface and made keyholes to hang the shelf on the nails on the wall.
Step 6: Folding the Sheets
Fold the sheet according to the angles given in the drawing. I used sheet bending machine to get the correct angles.
Step 7: Sanding and Painting
After finishing with the folding, sand the pieces in the grooves, holes and overall body. Sanding gives a smooth surface finish. Now apply the primer coating to the pieces, let them dry and then apply water based paint. I choose mint color.
Step 8: Final Assembly of the Pieces
Join the pieces as given in the video. Now take the rope and pass it through the holes as given in the second video. Pass the ropes on both sides. After passing the rope through holes, tie knots at the end as given in the images.
Tip- Use a small piece of cello tape at the tip of rope being used. It allows easy passing of rope through holes.
And it's done:)...You can even increase or decrease the number of pieces as per the need.
Thank You for visiting!
Organization Contest
Be the First to Share
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    • Hot Glue Speed Challenge
    2 Discussions
    audreyobscura
    8 months ago
    Sheet metal benders are so fun! What a great use of the tool to create a project that comes together with just fasteners and no welding!
    KritiK6audreyobscura
    Reply 8 months ago
    Thanks! It's really fun to work with metal sheets
